  • Total Members: 376
  • Latest: Andrew
  • Total Topics: 479
  • Online today: 55
  • Users: 1
  • Guests: 25
  • Total: 26
  • THB
What did you do aeroplane wise today?
Started by TheLurker, Dec 26, 2025, 10:58 AM
ramses
#210
Quote from: TheLurker on Jul 20, 2026, 11:06 AMGorgeous.
Ramses> I am going to use VMC aluminium colored tissue for this Spit..
Good luck with that, seriously.  It's currently 3-1 in favour of the tissue in my attempts to use the VMC Al. tissue. I've not been able to get it to shrink to a properly taut state, especially over compound curves.
Thanks!
And i know what you mean!!
I have used it on a few models now, and fully agree with you, it sure isn`t the easiest tissue to work with.
But it will save the weight of a thicker alu paintjob, i now just have to 'mist' the alu paint with an airbrush over the Spit.
Cheers, Ramses
billdennis747
has anyone ever accurately measured the weight difference between silver tissue, which cannot be applied neatly by mere mortals, and a thin coat of aluminium over black esaki?
Lastwoodsman
#212
What did you do airplane wise today?
Friday July 24 0206
      I just went out for a short walk in the low wind and in the heat,  with the  30"  Beaver.    I had four flight sessions in the last two days -  the Beaver flies well after all of that nose repair.  Today I just got two nice pics on two flights of six  seconds,  and the wind was getting too gusty,  so I quit.  I really just wanted to check the grass on the Cricket Field that they cut yesterday.
Pic #1    4229
Pic #2    4229 snip  closeup
Pic #3    4230
Pic #4    4230 snip  closeup
      I will just post a few pics in my Beaver Thread for the last two days combined,  in a bit.
    I really must get on with the  30"  Gipsy Moth build,    but we have had really good rain so far this spring here in the city,  but the county,  full of farmland,  did not get the rain we got.
    Happy flying!
Lastwoodsman
Richard
Prosper
Happy flying to you too, Richard.
Yesterday in fact - I didn't have time to post yesterday - I rescued this little 11" span test model from a cornfield. It had been flying on two strands of 1/16" rubber but was lame. I only have two sizes of rubber: 1/16" and 3/32". So two strands of 3/32" was a big step up - the model responded by flying into the cornfield despite the increase in its already monster wingloading.
The model went down near a low sun too, so I could barely see it - no idea of how far away it was. I looked behind me and got a good fix on a telegraph pole; looked ahead and fixed a funny lopsided treetop. Then I struggled my way onto and into the cornfield. The corn isn't yet as high as an elephant's eye, but is doing very well considering the drought conditions. I waded out until I was on my telegraph pole-treetop line of reference, and spent 5-10 mins slowly advancing and getting more despondent until I spotted the model sitting high on a leaf. Which was a great re-leaf, you might say.
This is a geared model with a 3", 75mm prop disc diameter. While my proper flying field is out of use I've been tinkering with some different gear setups, and I think I'll start a thread on the subject.
Stephen. p.s. excuse all the clumsy packing behind the gear-plate in picture 2 - I had to change the thrustline several times.
Lastwoodsman
What did you do airplane wises today?   Sunday Juny 26 2027
     Hi Stephen.    That is a great looking balsa-sheeted test model,  with that excellent 3 blade wood prop!   And the Gods of Free Flight were truly smiling on you,  when you found your test model in the cornfield!
     I am looking forward to your build thread on the subject.
     Long live the  'core' !    ;D   8)
Lastwoodsman
Richard
Lastwoodsman
#215
Mon July 27 2026
No-pressure,  Relaxing  and  Therapeutic,  Water Based Acrylic Painting,  Blending Experiment,  & Practice.
    I thought I would give it a try ....   :)
Pic #1    4242
Pic #2    4244
Pic #3    4247
Lastwoodsman
Richard
Prosper
Today I flew the little 11" span model pictured above into a tree. High. That's the problem with flying in a confined space. With a hardly detectable breeze, even a teentsy model can fly into trouble. It was the first near-full turns + fairly well trimmed flight. I counted about 20 seconds and it looked like it had only just begun its descent. Anyway, that's all I need to know. I suspect the valuable bits (prop and gears) will stay intact. The airframe took two or three hours to knock together so that's no loss.
The important finding is that despite a very high wingloading for such a small model (0.101g/sq cm, or 0.65g/sq inch) the 3" prop can fly it. I'm thinking of  larger scale models with lower wingloading.
Stephen.
ramses
Today i gave the Supermarine Spitfire F Mk.24 VN318/E some weathering, from:
To:
(also changed the elevator hinge line)
Cheers, Ramses
Lastwoodsman
Tue July 28 2026
That flew well Stephen.   I'm looking forward to the  "larger scale models" ....
That is some nice weathering on your Spitfire Mk 24  Ramses.
A couple more practice water color Art pics.    Progress has been made.
Pic #1     4248
Pic #2     4253
Lastwoodsman
Richard
Lastwoodsman
Tue July 28 2026
And here are the final two pics of the finished practice Water Color art painting of a Biplane.   I did try some blending of colors,  in there.
Pic #1     4258
Pic #2     4264
Lastwoodsman
Richard
Piecost
Ramses, your Spitfire looks fantastic! I hope that you do not damage that lovely tissue.
I performed glide tests on my blue foam Peanut Morane-Saulnier L. This was to confirm the the landing wire rigging, which had been tensioned to obtain a little dihedral, resulted in a stable flight. This was confirmed, so I will proceed in adding the rest of the flying wires.
The wings lack stiffness despite a 1mm carbon strip being embedded into the foam. Whilst the dihedral shape is somewhat uneven, since it glides well; I will not try to improve the shape.
The model is based on the fantastic stick and tissue plan by Ulises Alvarez.
Anyun
#221
Good looking little Morane-Saulnier Parasol with a nice patina
billdennis747
The Max Holste is just about finished and I may try it at Oxford on Saturday if I can find some fuel proofer It's 45" with a Doonside Mills 75
MKelly
Very nice Bill.  I still have that plan in my build file for CO2.
Good luck with the flights!
Mike
dputt7
Very neat Bill, what paint did you use for the Silver.
