News:
Main Menu
  • Total Members: 357
  • Latest: ChrisH
  • Total Topics: 438
  • Online today: 42
  • Users: 1
  • Guests: 34
  • Total: 35
  • THB
Veron Chipmunk
Started by pedwards2932, Jan 09, 2026, 01:13 AM
pedwards2932
Getting down to final countdown. Not sure I like the antiglare black in front of the windshield.  I was a little nervous about taping it off and painting so I did it in vinyl. Got to build the nose portion.  I won't be able to add the prop or test fly until I get it back home.
pedwards2932
Okay ready to call this one done.  When I get it back home I will build a prop for it and test fly it.
ramses
Beautiful Chippy!
Good luck with the test/trim flights.
Happy landings,
Ramses
pedwards2932
Thanks hopefully test flight in May
Marc Guerriero
Very nice! It blows my mind how it can be built with Styrofoam formers.
AndyB
Good luck with the test flights.
Any idea what it weighs?
A.
pedwards2932
It is 19g without rubber or prop assembly.
gravitywell
COME ON!  I mean, who doesn't love a yellow Chipmunk!  Looks beautiful.
AndyB
Quote from: pedwards2932 on Mar 04, 2026, 05:25 PMIt is 19g without rubber or prop assembly.
Ooh, that'll go well.
Istvann
Beautiful work!
Could you explain how do you work with the Cricutter? E.g. which files do you use, dxf, svg? Own drawings? What material thicknesses are possible in balsa and foam(depron)? May be a short "tutorial"?
Thanks,
Steve
pedwards2932
I use Inkscape. I import pdf plan files and trace the parts.  This gives me an .svg file and the Cricut Design space works with svg files.  It will cut up to 3/32" which with the size planes I use is plenty.  If I need 1/8" I just cut 2 parts 1/16 and laminate them together.  I have been using meat packing tray foam but recently it hasn't been working as well.  I started using Hefty foam trays.  They are about 1/16" thick and pretty stiff.  I did a tutorial on tracing pdf to convert to dxf files a few years ago not sure I can find it.  Inkscape is fairly easy to use and with the Cricut using svg files there is no conversion.
Istvann
Thank you! The most important for me was the thickness of the materials. I'm working with Turbocad an can convert the files in svg. Have agood flight-time! Happy Eastern!
