Members
Stats
  • Total Topics: 444
  • Online today: 395
  • Online ever: 395 (Today at 06:54 AM)
Users Online
1/24 scale DH Mosquito for rubber power.
Started by Prosper, Jan 10, 2026, 08:35 PM
Previous topic - Next topic
Prosper and 4 Guests are viewing this topic.
Piecost
Interesting experiments. I too have thought best to not cover in extreme conditions. We are back to the usual cool and humid enviroment. What are you using to glue the tissue down with?
Jmk89
Quote from: Prosper on Sep 14, 2026, 07:46 PMP.S. I see that when posting, people can place images within text - some text; a photo; more text; another image, etc. How does one do this?
Stephen
Let's assume you've written all the text and clicked/dragged your photos into the box at the end of this he draft post.
If you look at the thumbnail of a photo you will see in the top RH corner an arrow symbol.
Now put the cursor in the text where you want to locate that photo and click
Then click the arrow symbol on the photo
A box will pop up - just click in INSERT and that will put the photo in the text where you clicked the cursor
All the best
Jeremy
Better drowned than duffers, if not duffers won't drown
Prosper
Thanks Jeremy! Will try this on my next post with multiple piccies.
Tim, I'm a long-time adherent (cough) to wallpaper paste glue. In my case this is something called UHU Glue Pen. It's gloopy, transparent (apply with an artist-type paintbrush of the relevant size), and water-based. Whatever it is chemically, it dries to an astoundingly tough transparent, flexible membrane. I've sometimes wondered whether it could be layered onto a form to make a cockpit canopy. I guess the answer is yes - but it dissolves when wet, so probably not very practical!
Stephen.
Prosper
I've been unable to do any work on this for the last 3 weeks, but after my last post, I had started on the demoralising chore of making the exhaust stacks. I tried everything - twizzling some balsa dowel then shaping it and trying to bend it with heat . . . carving each stub independently (too inconsistent, too time-consuming) . . . short forays into shaping plastic tube; moulding, casting different materials etc . . . all of this hampered by the stipulation that each exhaust stub must weigh not more than 0.0 grams . . .
One immediate difficulty is that I don't know what their exact shape is, in the first place. Few wartime Mosquitos seemed to have this type of stack. I've leant heavily on a New-Zealand 'late-production' example, even tho' this is brand new and I prefer to model from original examples. Curiously, look at lots of period Mosquito photos and the great majority of day Mossies had exhaust anti-glare shrouds, whereas most night Mossies pictured have bare exhausts - hmmm - wrong way round, surely? Maybe to do with performance - shrouds reduced engine power output.
The pictures are just to suggest what kind of things I was trying.
Prosper
The last pic is where I'd got to when I had to stop work. Sort of mass-production with individual finishing. There are twenty of these suckers to make.
Never mind - I've got all winter to do this . . .
Stephen.
RolandD6
Seems to me to be a prime candidate for making a good pattern out of firm polished wood, making a silicon rubber mold and then press molding replicas from lightweight paper clay. The type of silicon rubber used is very expensive for little jobs like this but there are people on YouTube etc. who will try to convince you to make a mold from adulterated silicon sealant. I have not tried this because I already have more than enough genuine silicon rubber from past projects. Another possibility is latex rubber which is relatively cheap. I believe the normal method of making a latex mold is successive thin coats allowing the coats to dry before applying the next coat. You have to provide sufficient time for the water content in each layer to evaporate.
Just a suggestion
Paul
Jmk89
If you're going to try moulding using paper clay, perhaps the pattern could be moulded from wax, like a piece of jewellery being made using last wax casting.
I've never tried it, it's just a thought that popped into my head when I read RolandD6's post. Forming wax might be easier than carving firm wood, especially as you could make the basic round rod by pouring warmed wax into a split tube. ISTR that Bill Dennis wrote an article in AM in the 80s on wax patterns that he used to make exhausts by electrolysis with copper solution. Adapting those techniques might get you to a good result and leave you more winter for other things, Stephen
All the best
Jeremy
Jmk89
I mean electroplating not electrolysis and the article was in March 1983.
I apologise for the mistakes
All the best
Jeremy
Prosper
Many thanks Paul and Jeremy - I had considered 'lost wax' but these exhaust stubs are so small and thin that I doubted my ability to make wax examples (examples, plural, because there must be one left-hand and one right-hand example). I have RTV silicone from other, full-size uses, but . . .duuuuhhh . . . from my previous use of RTV silicone I only thought of moulds split into two halves - again, too awkward for these tiny components. But - of course given the felxibilty of silicone, perhaps a lost-wax or lost-balsa or something form could be pushed out of a solid (one-piece) silicone mould . . . Thanks for energising all three of my brain cells . . .
What is 'paper clay'? It's all right; I won't feel betrayed if you tell me that it weighs more than 0.0 grams per CC. :)
Stephen ps yes i do have other (aeromodelling)things in mind Jeremy, for the winter
OZPAF
Instead of carving - perhaps bending insulated wire of the required thickness would work for plugs for your mould. It could be flattened as required and a bank of them attached to a baseplate, and moulded as a unit.
I like Jeremy's idea of using electrolysis onto wax - but at this scale it could be flimsy. I believe this was used on a French aero engine of the first world war to make the copper water jackets around the cylinders.
John
RolandD6
#190
The following are examples of paper clay that I have. Two are made in Japan and the clay in the round tub is made in Australia. So far I have only used the middle example. I was able to press mould it and cast it by thinning with water. All of them are very light weight. The two examples on the right come in a variety of colours and all can be painted.
Paul
OZPAF
Quoteelectrolysis
Whoops! copied Jeremy's mistake - electroplating is the right word.
John
