News:
Main Menu
  • Total Members: 376
  • Latest: Andrew
  • Total Topics: 481
  • Online today: 68
Junkers Ju390
Started by dputt7, Jan 26, 2026, 11:30 AM
Mr Speedy
Hi Dave! Good to see you here too! Hopefully that means that you are coping with your challenging situation?
    Yes, it's nice to be back on HPA! I've got a bit more time now, so I'm trying to round up my " ducks 🦆 ", in an attempt to get them into a row! But hopefully that will mean cutting wood soon!   It's cool that someone photographed your plane flying and the photo wasn't lost!      I'm watching with interest as usual!!
dputt7
Progress has been a bit slow lately but I have managed a bit.
Made up the 2 outer wing panels Photo 1.  Photo 2 shows the outer wings carved and sanded.  The out panels will be made detachable for transport and mainly to prevent damage in a hard landing.
In Photo 3 the dihedral is set and 1/8th brass tubes are set in place against the spars. A wood spacer with slots to clear the brass tubes is clamped in place between the root ribs and the tubes glued in place.  Photo 4 shows the balsa glued against the tubes, these will be filled with glue and vertical grain gaps glued in place over the tubes.
dputt7
  The Root ribs are faced with 1mm ply and then sanded Photo 1
The center section has the root ribs faced as well and I have sheeted the front of the wing and have added sheet for the nacelles. I should have thought about this when I laid out the ribs and spaced them to suit the nacelles, it would have been neater. Photo2.   Finally the completed wing so far. Photo3
                                               Dave
dputt7
#18
  Hi, next step is the mounts for the motors. As the wing is set at 3degs. positive Incidence I wanted the motors to sit level with the fuse so they already had 3degs. downthrust relative to the wing. the motors will be adjustable so I have drilled the motor mounts above the center line so I can increase the downthrust if required and the prop shaft will be in the center of the cowlings.
  To this end I made up a jig with some brackets set at 3degs.to hold the wing in place, the ply mounts could then sit squarely on the bench while the epoxy dried. Photo 1.  Photo 2 shows the completed motor mounts while Photo 3 shows the underside mounts and gussets as well as the strips for mounting the lower Nacelles.  Next up is making the inner Nacelles.  in Photo 4 you can see the jig I made to hold the form in place. The inner Nacelle has a bulge on the lower side to contain the landing gear so I spun the form into shape on the lathe. I then cut off the lower third and replaced it with a block of balsa and carved it to the bulging shape. I then mounted it in the jig with the underside up and molded a lower nacelle. I the removed the screws and turned it 180degs. to mold the top Nacelle.
dputt7
  Here are the Photos
OZPAF
That's a neat clever approach to making the nacelles and jigging the motor mounts, Dave.
Happy building.
John
dputt7
In Photo 5. you can see the setup for the Outer Nacelles.  As they are the same upper and lower I spun up the form in the lathe and mounted it so I could form the Nacelles, Finally Photo 6 shows the top inner and outer Nacelles in place.
dputt7
Lastwoodsman
Wed march 25 2026
     Hi dputt7  Dave.   That is a very interesting and excellent build of your six engine Junkers Ju390 plane!     8)      Thanks for all of the pics and info!
Lastwoodsman
Richard
dputt7
   Thanks for your interest Richard
dputt7
   Hi, this seems to be going on forever :o .
I've managed to cover all the flying surfaces with PolySpan and given them a couple of coats of dope to seal them. PHOTO 1-2.
Next up I've fitted the Nacelle moldings for the top and bottom of the wing Photo 3-4 shows the top fairing and Photo 5 shows the underside with the Fatter Nacelle to house the landing gear, I have a fair bit of filling and touching up to do yet!
You will notice an orange stain on the covering, this is caused by using debonder to remove some unwanted spots of glue. Just as well it will be painted.  Finally in photo6 you will see I have made a start on the engine cowlings, Plunge molding them over a form to make the front cover.  That's it for now.
                                                 Dave
dputt7
The rest of the Photos.
Prosper
Quote from: dputt7Hi, this seems to be going on forever :o .
Great work Dave. Big project . . .:)
Squirrelnet
As Stephen says... Very much enjoying watching it come together this end :-)
dputt7
  Thanks Stephen and Chris, I appreciate your interest.
