Members
  • Total Members: 376
  • Latest: Andrew
Stats
  • Total Topics: 481
  • Online today: 68
  • Online ever: 484 (Oct 19, 2026, 11:51 AM)
Users Online
  • Users: 1
  • Guests: 13
  • Total: 14
  • Footrot
Recent topics
Miles M5 Sparrowhawk by Walt Mooney
Started by Stunthenk, Jan 27, 2026, 12:01 AM
Previous topic - Next topic
Stunthenk
I cut some very fine black tissue stripes to mark the ailerons. On previous models I used a black marker, but I wasn't really happy with the result. After these lines were doped on, the backsides of the letters were doped and when still wet, applied to the wing. It was done this way because the silver tissue is not very permeable for dope. The fin received circles of white decal, roughened beforehand with 1000 grit sandpaper or nothing would adhere. Well, at least not permanently... Then race number 3, cut from black tissue, was applied with tissue paste. In the picture the port wing has already had its 2nd coat op dope and is pinned down in its 'cradle'.
In the mean time I made the wheels. For a larger model I would use several discs of balsa; for a peanut I used a disc of 1,5 mm balsa sandwiched by foam discs. The discs were cyano'd to an overlength alu bearing and each other, and finished in a drill press running at low speed. I used to hold the sanding block in my hand but nowadays I mount it in a machine clamp which I press to the disc VERY GENTLY to avoid the wheel from breaking loose from the alu tube, but getting better roundness than with a hand held block. The wheel profile is rounded with hand held sandpaper, however.IMG_6116.JPGIMG_6115.JPG
Stunthenk
Made some progress on the Sparrowhawk. Applied the stencils and airbrushed the registration; might have been a bit more accurate but I'll live with it. Cut the windscreen size from the plan, but first I bent some thin bamboo over a hot soldering iron to have something for the windscreen to adhere to. The shape from the plan was not accurate so I drew a modified shape with the aid of an ellips drawing template, cut a shape from paper and that fitted better. I wanted to glue the plastic with medium CA but that brings the danger of fogging from the drying glue. Therefore I dipped the plastic in Future floor polish. This is a clear acrylic liquid that brightens clear plastic by filling minute scratches and CA fog does not adhere to it.
Then I epoxied the undercarriage legs to the underside of the wing, and cut the 'trousers' from thick paper. This time the shape on the plan turned out to be perfect. But I found out that my wheels, made to the size on the plan, were too big! Therefore I made a new set of 'racing' wheels; somewhat smaller and well tapered.
Stunthenk
With the main components finished, the model was glued together. Then I spent some time makin the wingfillets from soft block; alsways nice to shape block balsa. The fillets were hollowed out and tissue covered before glueing them to the model. The 'trousers' remained; fitting them was a hassle. I managed to get the starboard one fitted, but unfortunately it is slightly canted to the right. And as the trouser is glued directly to the tissue, it will be difficult to correct. Perhaps I should leave it and glue the port one at the same angle?IMG_6177.jpgIMG_6178.jpg
TheLurker
Ένας χωρίς μια ιδέα ή, αν προτιμάτε, clueless  :)
