News:
Hip Pocket Aeronautics Plans Gallery up again:
https://hpa.aeromodelling.gr/plans/index.php
Main Menu
Members
  • Total Members: 357
  • Latest: ChrisH
Stats
  • Total Topics: 440
  • Online today: 152
Users Online
Recent topics
Cessna Cardinal
Started by 9600baud, Apr 24, 2026, 09:15 AM
Previous topic - Next topic
9600baud
Hi all,
here comes another No-Cal, this time scaled down to 75%.
It's very fragile. At the maiden flight I realised one wing was warped and I had to fix that. After that and a bit more of down thrust it flies nicely and I'm happy :)
Wingspan: 305 mm / 12"
Weight: 2.3 g without rubber
Rubber: loop of 27 cm of 1 mm2
Here is a short video:
Cheers
Alex
dputt7
Nice build, what did you do between the 2 flights. it slowed down and flew better, less rubber?
9600baud
Thanks!
The motor was the same. It was 900 turns for the first flight and 1000 turns for the second.
To me it the speed looks quite even but you might have a better eye for this :)
Konrad
Great job.
Love all that use of heavy iron to build this ultra light small model!
Many folks don't understand how important having well defined datums are to a nice finished project.
Cut it twice and it was still too short!
9600baud
Here it comes again, a reincarnation of the Cardinal, this time at a 100%, so 16" :D
It's really nice and slow.
At the beginning the fuselage gets a bit twisted and that's why it doesn't want to climb in the first circle, I think.
Cheers
Alex
g_kandylakis
Tight turn at the beginning, wide as the power runs down.
Try more right thrust and more left rudder.
Nice flights, look promising as long as you can avoid the walls and hiding behind large objects  ;D
George
MEETOO
I really admire your approach. This looks like you know how to sort out stuff. Looking like you have done this for a good while and also have great facilities available to wind um up. Thanks for sharing your Cardinals.  What is the next one gonna be?
MEETOO
9600baud
Thanks, yes I have a sweet spot for easy and quick to build models :)
Right now working on a small Cessna 140. I currently have a bit of trouble to access our indoor flying site. Let's see, maybe more news tomorrow.
Alex
