  • Total Topics: 483
  • Online today: 60
  • Users: 0
  • Guests: 13
  • Total: 13
Miles M5 Sparrowhawk
Started by Robert McKellar, Apr 28, 2026, 01:52 AM
Robert McKellar
So here's my take on the Miles M5 built from Walt Mooney's plan OZ1193.
 I printed the plan at 1/20 scale which gives a span of 16.8". I drew my own wing and Htail plans to build over as the drawing was a little wonky and not quite symetrical.
 I raised the wing in the fuselage a little bit to better match photos which show the fuselage protrudes below the wing. The fin shape was tweaked again, to better match photos.
 The tail features a built up airfoil cross section and I used scale rib spacing on all flying surfaces. The wing uses the Dave Reese style construction with 1/20 square ribs. The upper ribs were laminated from two layers of 1/20 x 1/40 balsa.
Robert McKellar
And here's some shots of the wing construction.
 This model will have seperate control surfaces mainly because I like the scale look. The spar joiner is 1/64 ply.
dputt7
TheLurker
Very nice work.
Take it you've found a fairly easy way to reduce image file sizes.
g_kandylakis
A very nice and light construction!
Robert McKellar
Thanks for the kind remarks!
 Here's the model all framed up and at this point it weighed 8.8g
cvasec
malc
What he ^ said!
Sounds very light for the size.
M.
Robert McKellar
 For covering I use Asuka tissue with nitrate dope and sanding sealer over the bare balsa sections. Just needs a windscreen, paint and I'll be building a section of a dummy cylinder to fit in the nose. It will need some nose weight so might as well be scale detail!
 The weight after covering is 12.33g which I'm very pleased with.
Cheers!
Rob
OZPAF
Very impressive work and interesting structure topped off with a neat covering effort.
Good luck with it.
John
Robert McKellar
Quote from: OZPAF on Apr 30, 2026, 03:03 AMVery impressive work and interesting structure topped off with a neat covering effort.
Good luck with it.
John
 Thanks! I'll be one nervous chap on flight day!
gravitywell
Beautiful model of a beautiful airplane.
lincoln
Some people are more patient than I am.
Stunthenk
It looks as if you've used a flat bottomed wing section. Correct?
Robert McKellar
Quote from: Stunthenk on May 01, 2026, 01:04 PMIt looks as if you've used a flat bottomed wing section. Correct?
 Yes, I did use a flat bottom airfoil.
 They perform better than conventional airfoils at low Reynolds numbers and it makes building a lot easier.
