Members
Stats
  • Total Topics: 428
  • Online today: 34
Users Online
Recent topics
Piper PA-18 Super Cub by Guillows
Started by ZIP.58, May 08, 2026, 10:36 PM
Previous topic - Next topic
0 Members and 2 Guests are viewing this topic.
ZIP.58
(Part 2)
The center of gravity is marked on the fuselage and wing spars according to the plan. Now it's time to use one of my balancing devices. It consists of a piece of linen twine with a thin pin attached to each end. These are inserted into the wing spars, and the model is suspended from the twine. Tail-heavy—I didn't expect anything else! Pieces of putty are placed in the nose until the center of gravity is correct. I trimmed the model to be slightly nose-heavy. Two-thirds of the putty weight was glued into the nose in the form of pencil pieces; the rest remains as putty to allow enough clearance during flight testing. Trimmed weight is now 81 grams.
ZIP.58
(Part 3)
And now??? Measure the technical specifications and then take it for a test flight as soon as the weather permits!
But what is the correct wing area, and what is the wing loading?
Wing area: 8.80 dm² (A); tail wing area: 1.15 dm² (B); fuselage area: 0.35 dm² (C).
If I use only the area of the wings (A), that comes to about 9.20 g/dm²; if I include the tailplane (A+B), it's 8.14 g/dm²; if I calculate using all three (A+B+C), I get 7.85 g/dm². In any case, it's under 10 g/dm², which promises a model that flies well.
Thus, the Guillows Kit No. 303 "Piper Super Cub 95" has been transformed into a "Piper PA-18-150 Super Cub" through modifications to the cowl. Although it is now "laser-cut," the design, according to the year indicated on the blueprint, dates back to 1961!
The build was a lot of fun. I hope you enjoy following the thread, too.
Peter
OZPAF
It looks very impressive Peter.
What a great looking collection of models in your workshop.
John
ZIP.58
Last Sunday: Warm, calm weather. Just right for model flying and breaking in the models! First, I took some photos of the Piper—you never know. Then came the maiden flight. Even the very first trim flight ended in a beautiful, long, and stable glide of about 50 meters. The subsequent flights yielded the same results.
Wound the rubber band to 200 revolutions. Stable flight with a tendency to veer left, without much climb. The same pattern continued up to about 300 revolutions. Above that, the rubber band (gray, 2 strands of 3/16" from the kit) started behaving strangely. Despite good lubrication, the strands stuck together and no longer formed clean loops. The model was literally torn into the sky as it climbed steeply.
During one of the landings, a wing strut broke, which isn't a big deal and was repaired that very same evening.
Conclusion of the day: The model flies! It will get a rubber band from my stash (FAI Tan Super Sport 3/16"), and the kit's rubber band is going in the trash.
ZIP.58
...and on the fly
chris46
Congratulations on your successful first trim flights! Now you're ready to win a "flowerpot" at the Guillow's Competition in Olten.
Chris
OZPAF
That looks very promising - good luck.
John
