News:
Main Menu
  • Total Members: 375
  • Latest: Bayeux
  • Total Topics: 479
  • Online today: 59
Ryan NYP
Started by TheLurker, Jul 05, 2026, 10:53 PM
0 Members and 3 Guests are viewing this topic.
TheLurker
Morning John,
The plan is to cover the nose with aluminium leaf and 'twizzle' it to get an engine turned effect so the name will have to be applied as separate letters; either tissue or paint/ink.
However it happens it's going to be a slow old job with lots, oooh lots and lots, of room for making a mess of it. :)
OZPAF
That was a massive oversight on my part ;D  Engine turning printed on silver coloured tissue ?
Hmm! I guess it would not do the model justice!
John
TheLurker
Finally able to get some work done this weekend.
One wing, waiting shaped tips, & a new outline for the, now, slightly enlarged tail-plane.
The new tail outline needs at least another couple of days to set properly, but hope to make a start on the fin & rudder tomorrow.
TheLurker
On to the fin & rudder.  Lot of hurry up & wait in this hobby; this is a couple of evenings effort.
1 - Glue the rudder post & rudder LE at the desired separation.
2 - Lift off the board & insert hinges.
3 - Pin down & build the rest, slowly. :)
4 - And we're done.
Compact wee beastie isn't it?  Outline is 1/20 x 1/32 basswood the remainder is some delightful stiff 5 lb/cu.ft 1/20" stock I got from Dusty Millar a few months ago.
TheLurker
Next little bit.  The tail-plane.  More pins Igor!
TheLurker
Also made a start on the spinner/prop.  Probably have yoghurt pot blades.  Got to find a yoghurt pot though...
The Al tube is cyano-ed to the ply disk just to keep it aligned while the balsa discs are fitted.  The first couple of balsa disks are fixed with epoxy to ensure a solid fixing to the Al tube. The remainder have been fixed with PVA.  If time allows I'll shape it tomorrow,
TheLurker
Spinner finished.  It probably took longer to make the profile gauge than it did pare & sand it to the final shape. The prop. shaft will be secured with a thin smear of 5 minute epoxy.
1 - Profile gauge(*) for final check & marked up for rough shaping.
2 - Roughly shaped.
3 - Final check of shape
4 - In situ.  May have overcooked the baked in right thrust, but that's fixable.
(*) Like Chris, I don't have a lathe. :)
TheLurker
#67
And after today's go at the spinner, tomorrow's (or maybe the day afterwards) task...
This one is going to be hand launch only, there just isn't enough UC clearance to allow for anything approaching a reasonable diameter airscrew.
TheLurker
Plodding on.
1 - One spinner & prop assembly. It's 4" diameter and the pitch is close to that of the equivalent dia. Peck/VMC prop. I'm hoping that I'll be able to trim it down during trimming so that ROG is possible, but no matter if I can't.
2,3 - Wheels. Blanks & part done.  No startling new techniques here. Four by 1/32" layers x-grain per wheel, fine Al tube axle. Solid discs for the core & hoops for the tyres.  I'll finish shaping the second wheel tomorrow or Friday. Long past this Lurker's bed time and it'd be silly to rush it. :)
Haven't been able to find a good head on image of the wheels for gauging the width, but in the snaps I have they look to be about the same width as the suspension fairing on the strut.  So laminate and when all set sand the tyres down to about 1/64" thickness on each side.  Looks about right.
TheLurker
A bit of experimentation today.  Nose legends.  Now, given the size, the ideal solution for crisp lettering and ease of application would be waterslide transfers, but for (perverse) reasons of my own I want to see if a decent result can be achieved by simpler (and cheaper) means.
1 - Lettering on test panel.  I'd hoped to be able to use tissue, but the lettering is just too small and cutting through tape, template and tissue in this case turned into a waste of tissue.  So I've gone for artists' layout paper (45gsm) instead.  The results aren't too bad and the inevitable white edges are, mostly, lost against the aluminium ground. The letters won't sit as flush to the surface as tissue would, but I'll live with it.
2, 3 Positioning the letters.  The experiment with carbon paper glued to a template and tracing on to the test panel to give a guide was a miserable failure hem hem less successful than one had hoped for. So back to my usual technique for lettering positioning :)
4 Position template roughly place.  Will thin use low tack masking tape to keep it in place.  I can see me having a lot of type II fun actually placing the letters, but heigh ho.
Light's going here now so the port side lettering will have to be cut tomorrow.
Prosper
Scooz me for being thick, but could you elaborate on your caption for pic.1 in the above post? I don't follow what you've done. The result looks v. impressive so I want to find out more. I did check back to post #58 in case that sets the scene for what you've done here, but it made things no clearer for me.
Stephen.
TheLurker
Quote from: Prosper on Nov 01, 2026, 03:33 PM...could you elaborate on your caption for pic.1 in the above post?
Sorry it wasn't clear. What I usually do is print the lettering template on 45gsm paper, tape it over appropriately coloured tissue and cut through. To save ink I print the templates as outline only.  It didn't work this time, I wasn't expecting it to, so I printed the nose legends as solid colour to 45gsm and cut those out.  That make more sense?
Today.  Cut out the port side nose legend letters, took around forty five mins to an hour, and did the "engine turning" on the nose. The engine/machine turning isn't great, but squinting from long arms length it just about passes muster.  Intending to start applying the lettering tomorrow after work, but it's a job that will require a fair amount of concentration so it will depend on how puggled I am.
Looking at what's left to do there is the very, very, slimmest of chances, if the stars align just so, that I'll have something testable for the next Trinity.
1 - Nose "gilded". Aluminiumed?
2 - With nose block in for giggles.
3 - "Turned".  Had to do this freehand. Tried using a guide as Bill suggested, but the piece is too small to hold the guide, nose & "twizzler".
4 - Testing that I can glue small letters to Al foil/gilding and that they'll stay put.
Prosper
Quote from: TheLurker. . .What I usually do is print the lettering template on 45gsm paper, tape it over appropriately coloured tissue and cut through.
What - so you done all them tiny spiral squiggly bits by cutting, with a scalpel blade? That's what wasn't clear to me - I didn't think such a thing feasible at that scale (known as 50p scale). Kudos.
The engine turning looks really good. More kudos.
Stephen.
TheLurker
Quote from: Prosper on Nov 02, 2026, 01:33 AMWhat - so you done all them tiny spiral squiggly bits by cutting, with a scalpel blade?
Alas, as much as I would like to claim to be some kind of micro/nano-cutting whiz I cannot. Chiz, chiz, chiz. :)
If you have a dekko at the attached you'll see that I've cut in fairly close to the tight spirals for the port S & both 'r's, but not all the way in. I did cut all the way into the spiral for the stbd S.  I also separated the o & f in "of" for the stbd side.  I think I'll recut those to match the port side, they'll be far easier to manipulate when I come to glue them on and slightly less likely to tear/fold when being placed. I did make a point of "punching out" the centres of the "P" and "O"s though.
1 - Port
2 - Stbd
3 - Where (& when) this all got started.
TheLurker
Too bushed to be able to concentrate on very small scale detail i.e. fixing the nose legends in place, see prev., today so finished off the wheels instead.
1 - Tissue discs backed with 45gsm paper
2 - Test fit
3 - Done & dusted.
One day I'll make some exactly circular wheels, not anytime soon thought.
