News:
Hip Pocket Aeronautics Plans Gallery up again:
https://hpa.aeromodelling.gr/plans/index.php
Main Menu
Members
Stats
  • Total Topics: 428
  • Online today: 62
Users Online
Recent topics
Ryan NYP
Started by TheLurker, Jul 05, 2026, 10:53 PM
Previous topic - Next topic
THB and 2 Guests are viewing this topic.
Prosper
Very interestin'. Re. my previous post about getting an urge to model NX211 every summer, the tiny tailplane is one of the off-putting factors. Bill Dennis has said that he has few qualms about small tailplanes (my interpretation of Bill's words), and I agree with him - I've flown rubber scale models with tailplanes 14% of wing area without problems - but I don't remember if NX211 even attains 14%.
Stephen.
TheLurker
Bit of arithmetic and redrawing this evening.
Running DeLoach's approximation over various permutations of tail plane size and it looks as though a 9% oversized (by area) tail plane will be about right for stability and won't look stupidly large.
I've increased the span rather than chord as I read somewhere (no, I really can't remember where), but it was years and years ago that a span-wise increase was more effective than a chord-wise increase.  Whether that's true or not I think a span-wise increase is less jarring to the eye
For those who need to know these things.
A 9% increase in area increases Vh (TVo) from 0.6 to 0.74 and gives an approx. CG position at 42% root chord.
A 4.5% increase in area increases Vh (TVo) to 0.66 and gives an approx. CG of 40% root chord.
DeLoach advises that for FF scale models that 0.66 <= Vh <= 0.75 is likely to give best results.
Of course this is all "wet finger in the air" with a large dash of haruspexy thrown in, but it's a bit better than wild guesses.
Ένας χωρίς μια ιδέα ή, αν προτιμάτε, clueless  :)
Jmk89
I haven't seen 'haruspex' since high school Latin classes (when it was not unusual for me to be thinking about something I'd read in the latest AeroModeller rather than the third declension).
All the best
Jeremy
Better drowned than duffers, if not duffers won't drown
Prosper
Quote from: Jmk89I haven't seen 'haruspex' since high school Latin classes . . .
I 'ent never sin it before. Forced to go to the dictionary. Lurk, the entrails of which animal did you use to make your divination? Not your pet cat, I hope. Re. the tailplane, I think that there are two things at play here - generally, a higher aspect ratio planform is always better for lifting surfaces; and propwash blanketing the tail surfaces is a bad thing, so extending the tailplane span out of the wash is a good idea. In your case I expect the whole tailplane will still be washed over, but perhaps less so at the tips.
Stephen.
TheLurker
Quote from: Prosper on Sep 17, 2026, 03:35 PM...the entrails of which animal...
Weel, chickens are traditional and you can eat the bits not needed for the divination.  Waste not, want not. :)
Piecost
Whilst I agree with Prosper that increased span (aspect ratio) will increase the effectiveness of the tailplane. I respectfully disagree about  propeller slipstream;
At higher power the increased airflow over the tail will increase its effectiveness. But, this tends to be overwhelmed by the destabalising effect of the propeller.
On lower power the propeller may actuallynbe reducing the airflow over the tail (blanking it), but the much reduced destabalising effect of the propeller will be dominant.
So, the stability tends to be lower at high power.
This is generally applicable, but depends on propeller characteristics and airframe geometry etc.
I think that a smaller, faster prop tends to be better than a larger one as it has less destabalising effects and blows more air over the tail. But; I'd be interested to hear other opinions.
Prosper
Yes, that's it, as I understand it - the accelerated airflow over the tail surfaces makes them more effective in terms of static stability - but that same airflow from the propeller blankets the tail surfaces from the freestream airflow somewhat, thus reducing dynamic stability - responsiveness to gusts and turbulence generally. There are pictures of piston-engined planes in humid environments - typically on board aircraft carriers - where the helical propwash vortex is visible. I'd like to know whether the vortex diminishes in diameter as it travels aft.
Stephen.
Piecost
Good point Prosper; I tend to forgot dynamic stability. It makes sense that the the slipstream blowing over the tail deminishes the the change in downwash that thw tailplane see, as the aeroplane pitches. Yes, the prop wash does contract slightly begind the propeller. I would need to check momentum theory to quantify it. But, this is digressing from Lurkers nice model.
TheLurker
I was going to say, "Digress away!" as I do like a thread that rambles, but it's not really a digression.  It has a direct bearing on the likelihood of getting the end result to fly.
Piecost
Back to the digression...
This is a screanshot from a video that came up on my Youtube stream. It nicely shows the condensation in the propeller tip vortices. Even though the visible vortices don't make it back to the tail; the stream of fast moving air does.
A contraction in diameter can be seen just behind the propeller. Similar to wingtip vortices. There also seems to be a general contraction as the air moves further aft.
Piecost
I can convince myself that the canopy causes a bulge in the slipstream "stream tube"
Prosper
#56
Great illustration Piecost - shows the real deal. I must say though that if I continue that visible contraction of the  vortex to the tail  . . . it still blankets the whole tail.
Having made scale (I mean fully-scale) models of both Me.109 and Fw.190 - both of which have ~14% Hz stabiliser area to wing area . . . the Fw.190  was more stable despite its longer nose (nose ahead of the CG). Perhaps because it has a high aspect ratio tailplane compared to the 109.
Frankly, at the low Reynolds numbers we deal with with our small, scale, models . . . there are so many variables and confounding factors - known and unknown, as per Donald Rumsfeld (?sp). An example is the phenomenally thick aerofoil sections of the Hawker Hurricane/Typhoon/Tempest. Combined with small tail area relative to wing area, the super-thick tailplanes destroy pitch stability. Bin there - don't want to go there again.
Sorry Lurk - hope I haven't digressed a digression too far.
Stephen.PS  just seen your post Tim-yes the bubble canopy is one of those known onknowns
OZPAF
QuoteSorry Lurk - hope I haven't digressed a digression too far.
I'm afraid I would like to add to the digression!
As your interesting photo indicates Piecost - the propwash stream tube would definitely appear to contract on leaving the propeller in a high velocity stream tube. However I believe it slowly increases in diameter as the the velocity reduces - a fair way behind the tail. A similar situation to the changes that occur with wing down wash.
As Stephen mentions - there are too many unknown variables and experience while considering theory, is probably the best approach.
Apologies Lurk.
John
