News:
Hip Pocket Aeronautics Plans Gallery up again:
https://hpa.aeromodelling.gr/plans/index.php
Main Menu
Members
  • Total Members: 331
  • Latest: OH-13-H
Stats
  • Total Topics: 376
  • Online today: 39
  • Online ever: 247 (Jun 15, 2026, 07:31 PM)
Users Online
  • Users: 0
  • Guests: 22
  • Total: 22
Recent topics
Tilted Sanding Block
Started by Jmk89, Jul 27, 2026, 11:57 AM
Previous topic - Next topic
Jmk89
No not the Earl of Norton but a device to help sanding strip into trailing edge stock because one is much more likely to  have some sheet the right thickness, grain and density than to find a commercial piece of TE that suits!
Today I started making another rubber powered plane. I'll tell you more about it when I am more advanced in the build (still waiting for a package of balsa from Balsa Central in Adelaide to get here so that I can start cutting ribs).
However, my balsa stock did have some suitable timber for the trailing and leading edges for the wing and I bent the bamboo wingtips using my usual heating-soaked-bamboo-around-a-template method.
However, I realised that I had not shown you guys my trailing edge sanding tool. I think I stole the idea (and improved it a bit) from something I read in Aeromodeller (it may even have been John Stroud's Golden Wings column in the mid-70s.
Here are a couple of photos.
Basically, as you can see, the heart of the device is a piece of 50 mm x 25 mm aluminium rectangular tube 150 mm long  (I think it's 3 or 4 mm wall thickness).
To each side. I have created two sliding "legs" which have 3 mm wide slots cut in them. 150 mm long. The slots are about 35 mm from each end. Then in the middle of both sides of the centre section at the 35mm point I so that a 3 mm cheesehead  screw can hold the legs solidly to the side.
In fact, one leg of the device could be just a piece of aluminium strip glued to the side with 1.0 or 1.5 mm projecting since normally the rear of the trailing edge edges that I use come down to about 1.5 or 1 mm. The other side, however, does need to move so that the block is angled to create a nice triangular piece of trailing edge stock.
If the trailing edge is 12.5 mm wide, the long leg needs to be set four times the thickness of the trailing edge because the block is 50 mm wide and 12.5/50 = 4.
Of course, I forgot to mention that a piece of 120 grit sandpaper is stuck to the wide side of one face of the centre piece.
I tend to take off 70% or so of the balsa using a razor plane and then use the tilted sanding block to take it down closer to finished dimensions.
Maybe sometime soon I will do a 3D printed version of this
All the best
Jeremy
Better drowned than duffers, if not duffers won't drown
Piecost
Thanks for sharing your setuo. I tend to break many wing ribs when sanding trailing edges after assembly. So, I am a big fan of sanding prior to assembly.
Jmk89
Yes, that happens to me too.
Have you tried putting a strip of masking tape across the rib ends ( one strip along the whole wing with about 1mm sticking to the front of the TE? It helps to protect the rib ends.
I still preshape the TE because even when using masking tape after construction because I find it easier to handle and there are fewer sanding strokes required at the end
All the best
Jeremy
lincoln
#3
Excellent idea. My guess is that you could do the same thing with a razor plane or other small plane.
Earl of Norton? I think I'm on the wrong end of the Earth to get that one.
Jmk89
Quote from: lincoln on Today at 08:28 AMEarl of Norton? I think I'm on the wrong end of the Earth to get that one.
When I typed the word "tilted" in the Subject line, the 'puter changed it to "titled".  So I gave some sandpaper a title.
All the best
Jeremy
Jmk89
I have designed a 3D printable version of the sanding block in FreeCAD.  However, the 3D printer is on the blink and I am waiting for the required spare parts.
Once they arrive and I have resussitated the printer, I will do a print as proof of concept.  After making any changes that the printed prototype sjhows are needed, I will do a quick tutorial on putting the thing together and using it to go with the STL files and put the lot in the Plans Gallery, so others can use it.
All the best
Jeremy
lincoln
Quote from: Jmk89 on Today at 10:17 AM
Norton as in Norton abrasives? I'm pretty sure that the title said "tilted" when I read it.
Jmk89
Quote from: lincoln on Today at 02:08 PM
Quote from: lincoln link=msg=5094 loodate=1785216531Earl of Norton? I think I'm on the wrong end of the Earth to get that one.
Yes I caught it before I posted, but still liked the joke
All the best
Jeremy
