News:
Hip Pocket Aeronautics Plans Gallery up again:
https://hpa.aeromodelling.gr/plans/index.php
Main Menu
Members
Stats
  • Total Topics: 419
  • Online today: 40
Users Online
  • Users: 0
  • Guests: 13
  • Total: 13
Recent topics
Mystery model
Started by Jmk89, Jul 28, 2026, 10:31 AM
Previous topic - Next topic
Jmk89
BTW
The vice (which I now see is called a pattern maker/luthiers vice) is available in Australia at Carbatec and Timbecon. Lie-Nielsen in Adelaide have Auriou hand stitched rasps which are equivalent to the Liogier rasps I have.
I must say, the prices have gone up quite a bit in the decade since I got mine!
As for Sloyd knives, these can be obtained on FleaBay pretty easily for a pretty reasonable amount.
I imagine that in the UK, Axminster, and in the US, Lee Valley, would be likely places to look for these kinds of tools.
All the best
Jeremy
Better drowned than duffers, if not duffers won't drown
Piecost
Thanks for the detailed explanation Jeremy. I consider carving props to be a nessesary skill to possess to be able to consider onself a well rounded aeromodeller.
Prosper
Quote from: Piecost. . .carving props to be a nessesary skill to possess to be able to consider onself a well rounded aeromodeller.
Blimey, that's me out, then.
Thanks for the artisan tool info Jeremy - yes, writing these things up does eat into overall modelling time available, but I think people appreciate the effort, by and large - and it's what keeps forums like this alive and relevant and entertaining.
Stephen.
Piecost
I completely agree Prosper. I have not yet been able to carve a wooden propeller. It is on my to-do list, in which case; this information will proove invaluable.
OZPAF
Thanks for that Jeremy. I have carved one balsa prop, but haven't used it yet! my approach was similar - basically razor saw and knife.
Good luck with your Mystery Model.
John
Jmk89
Quote from: OZPAF on Aug 28, 2026, 03:40 AMThanks for that Jeremy. I have carved one balsa prop, but haven't used it yet! my approach was similar - basically razor saw and knife.
John
Thanks John.
Prop carving is one of those things that is shrouded with unnecessary mystery and is not as hard as some think.  It is a skill that is acquired by doing and made better by doing it again
All the best
Jeremy
lincoln
Another reference, by David Dodge:
The Idiot's Guide to Prop Carving v2.02
https://gryffinaero.com/models/ffpages/tips/propcarve.html
I don't recall if I actually used it, but it's memorable for the quote from dannysoar at the beginning. "It is a source of national shame
that a single citizen should have to go
to bed unable to carve a propeller."
Prop carving isn't that hard, especially if you relax your standards. ;-) I've made several, including a right and left pair for a twin pusher. However, they are not Larrabee style, or paddle style. More like wider versions of the Wright Brothers' props from 1903. That is, too wide at the tips. I wanted to quit while I was ahead, and they worked fine. 1:30 on an all-sheet model is probably good enough, anyway. I've made a tiny prop for an indoor rc plane and a small one for a Parlor Fly, too. They all worked ok.
I want Paulownia! Not so much for props as for building a really light boat that I can carry around. Just the thing for flying rubber models off water.  Paulownia is hard to find in the USA. Illegal to grow in this state because they're invasive. Three or four years to get a lifetime supply. I wonder if it's ever used for pallets.
Jmk89
Lincoln
Not sure of your state  - the details just say USA.  Paulownia is used by wooden surfboard makers, so if there are any of them near where you live, they may have it.
It is also used in Australia by wooden boat builders, so that's another trail to follow.  It is very good for a light timber.
All the best
Jeremy
lincoln
There aren't very many surfboard builders in Massachusetts! I haven't heard of any boat builders using it, but that's an idea. Down south, there are vendors with pre-primed, finger jointed siding imported from China. Allegedly, it's made from Paulownia. I think boat people usually use cedar for light wood, but that's much denser. On eBay, though, it's cheap enough for model airplanes.
Jmk89
Covering almost complete:
All parts except port wing & vert stab/fin fully doped with banana oil over to remove the nitrate dope blush (which is why the port wing looks lighter than the starboard one).
Any guesses as to what model it is?
All the best
Jeremy
Jmk89
Okay chaps.
Here she is roughly assembled.  Any guesses?
Yes there are still things to do, such as:
  • freewheel clutch and thrust washer for prop
  • bend front rubber hook
  • fit rotary damper DT
and probably several other things I can't think of yet.  But at least you can see what she looks like.
PS  I've never seen one in the wild before....
All the best
Jeremy
dputt7
Jmk89
Goo9d news - trimming glides in the backyard were  successful.
What is the model?  Here's the answer:
The magazine (including the plan) are available in the Plans Gallery.
All the best
Jeremy
OZPAF
Good luck with the trimming.
John
OZPAF
Zaic's designs always have a certain design flair to my eyes.
John
