Members
Stats
  • Total Topics: 399
  • Online today: 49
Users Online
Recent topics
Dumas f9c sparrowhawk
Started by nickhawk, Aug 10, 2026, 04:22 PM
Previous topic - Next topic
0 Members and 2 Guests are viewing this topic.
nickhawk
Hello everyone
The Curtiss f9c sparrowhawk parasite fighter was always for some reason one of my favorite biplanes.Surfing around in the internet I found one kit from Dumas and without further thoughts I bought it.A week later I got a box which had the kit of the F9c and it contained some plastic parts, plans, instructions,but no balsa parts....My fault I was so eager to buy it I did not read the description.....But, I was determined to build it I had the plans and the parts so I blackmailed and bribed my friend Tasos who converted the plan into a file the laser cutter could read and voila.I started building it the worst part being stripping the 1,5 and 2 mm balsa stringers.It will be powered by a CO2 engine.I will use the ABS parts to make a mold for the wheel pants and the cowl.The cockpit will be balsa .
nickhawk
The left half of the fuselage and the side stringer glued
Piecost
This is a great subject and I look forward to following the build.
nickhawk
Almost done with the half left side cutting the stringers and sanding them to fit tightly was a time consuming work.Then the right side formers will be glued along with the stringers. At the same time I have applied 5 coats of release agent on the vac formed wheel pants and cowling provided by Dumas. I will then produce molds as the parts will be sturdier and lighter.
nickhawk
Empenage is started and after completed but not sanded put on the scale with 95% finished fuselage.
nickhawk
fuse and tail feathers.
Piecost
Looking good. Am I correct in thinking that you halved the width of the empenage leading and trailing edges? Did you do so on the fuselage formers too?
