Members
Stats
  • Total Topics: 417
  • Online today: 33
Users Online
  • Users: 0
  • Guests: 12
  • Total: 12
Recent topics
1/10th Hawker Hurricane
Started by Mark., Aug 26, 2026, 01:27 AM
Previous topic - Next topic
Mark.
Hello everyone,
I don't come on here much, but i thought I'd share a video of my build progress. Some of you may have already seen it, but for those that haven't, a few details.
Drawing done for me by Ivan Taylor. He left me with a lot of scope for how to build it. I've been able to add my own touches to the build, which I'm thoroughly enjoying.
Wingspan is just under 48" - so as near as damn it 1/10th scale.
Propulsion is rubber power.
I'll be using scale dihedral, but incorporating a gyro to assist with stability.
It probably won't be one for the purists, but hey ho, each to their own.
Currently working on the prop, spinner and hub assembly. This will feature pitch adjustment for the blades, so we can experiment with that at the trimming stage.
https://youtu.be/lmx4ovp_7UM?is=W3nvJRgrqkCPOUD7
Thanks for reading/watching. 👍🏻
Squirrelnet
Great update Mark, the Hurricane is looking fantastic. Looks like you are almost ready to cover ?
It's a hugely ambitious project with Gyro, adjustable pitch prop and big too for a rubber model but given your last model was a hugely ambitious and flew I've no doubt you'll do it again.  I suspect a gyro quipped rubber model could be a first
Keep us updated and welcome to HPA3  ;D
Loved the video too BTW :-)
Mark.
Quote from: Squirrelnet on Aug 26, 2026, 03:16 PMGreat update Mark, the Hurricane is looking fantastic. Looks like you are almost ready to cover ?
Thanks Chris. Yeah it's certainly getting there now. I have a couple of small details to add, but yeah, it's pretty much ready to cover.
I've always been the same - i just prefer the stuff that makes my brain work, thinking about how to get around potential obstacles and coming up with solutions to make things work. I think Ivan has enjoyed seeing how I've taken his design/drawing, but added my own ideas and touches to the build. As it is in the video, it weighs in at around 230g - that's including the 2s lipo and all the electronic stuff.
The adjustable pitch prop came about after a conversation with Ivan, as we were discussing some details of the model whilst he was was looking over it. I just had to engineer how to do it! I've kept it nice and simple, but it just required some accurate, close tolerance machining work. Plus, I've made all the parts for it out of brass, so that will help very nicely in the nose as a spot of ballast.
Yes i think you're right, it will be the only rubber powered gyro equipped model in existence too.
Funny you should mention the 'other model'. It's still not trimmed, and has proven to be a real challenge. It's been damaged more times than i care to remember, and i just needed a break from it. So i repaired it and shelved it. It just needs flat calm air to get the trim dialled in. Sunday just gone was flat calm. I only had a couple of hours spare, but i headed out and started the trimming process again. Back to the beginning. I just took it nice and easy, making small adjustments and observing what the Mosquito was doing. There were plenty of areas that highlighted i needed to speak with Ivan and download the thoughts out of my brain. Final flight and it clipped my stooge and damaged the starboard wing tip 😂
But, most importantly, i learned something about the model on every flight. All of this will be put into action when i go out trimming again, and i genuinely cannot wait to get out again. 👍🏻
Piecost
Fantastic model! I love the scale thickness flying surfaces. They are so characteristic of the full sized plane.
I admired the Doug MacHard plan for this reason, however the increased dihedral somewhat spoiled the effect. My Keil Kraft model definately did not capture the look of the wing at all well.
Can you explain how the wing D-boxes were constructed? I presume that ther were internal ribs.
Tim
Mark.
Quote from: Piecost on Aug 26, 2026, 09:35 PMFantastic model! I love the scale thickness flying surfaces. They are so characteristic of the full sized plane.
Tim
Thank you. Yeah it's got quite some depth to the wing chord! When Ivan drew it up for me, he commented on it being the thickest airfoil section he's ever drawn, but as you say, it's needed to keep in with the character of the real aircraft.
Regards the D boxes, I used the sandwich method to create the wing ribs, then retained the front section of each rib after they were cut to size. They were then cut up and placed within the D box to give the upper sheeting some support. I also put some 1/32 balsa in between each support inside the D box for additional support. I don't think they were needed in hindsight.
OZPAF
That is quite an effort Mark - thanks for the video. I noticed your neat adjusters - for the Gyro Platform and the tail - very neat.
How are you adjusting the propeller pitch?
Good luck with it.
John
Mark.
Quote from: OZPAF on Aug 28, 2026, 04:04 AMThat is quite an effort Mark - thanks for the video. I noticed your neat adjusters - for the Gyro Platform and the tail - very neat.
Good luck with it.
John
Hello John. Yes there's been some work put into it to get it to this stage. The adjusters are made out of delrin - it's light and takes a thread. The downside is you can't glue it very easily. But there's ways around that!
Simple really regards the prop pitch. It's a brass tube, within a brass tube to act as a support, then the inner brass tube sits inside a brass bush with a thread. The thread is home to a m3 grub screw, which tightens down on the brass tube passing through it.
Probably not the best description to get your head around tbh, so I'll try and upload an image.
dputt7
  Not sure if John was thinking the same as me but I thought it was adjustable in the air as are some of the Indoor models. ;D
Mark.
Quote from: dputt7 on Aug 28, 2026, 05:36 PMNot sure if John was thinking the same as me but I thought it was adjustable in the air as are some of the Indoor models. ;D
Yeah none of that mate. I could probably make something to adjust the prop pitch under power like the F1B/Wakefields, but it's more work than I can be bothered to undertake 😂
Squirrelnet
In flight pitch adjustment or not it's still pretty impressive,
Gyros are something I've not used but talking to Ivan he tells me they are installed at an angle which gives a turn to the model, how do you arrive at the angle and can you change it ?
Mark.
Quote from: Squirrelnet on Aug 28, 2026, 08:40 PMIn flight pitch adjustment or not it's still pretty impressive,
Thanks Chris.
Yeah that's correct mate. So if you set the gyro up level, it will maintain a straight and level flight. Not ideal! So you install the gyro on an adjustable platform, which then allows the model to bank in the desired direction of turn - to the right in the case of the Hurricane.
You arrive at the desired angle at the trimming stage, so adjusting the platform and test gliding/flying the model to evaluate the level of turn.
For the Hurricane I've made the platform out of carbon sheet and tube, with a threaded delrin adjuster. You simply turn an m3 cap head (nylon), to adjust the angle that the gyro sits at. It shows the platform in the video, but maybe the adjuster is not that clear mate.
OZPAF
Thanks for the explanation Mark.
Dave's comment re in flight pitch change would be an interesting complication but I'm not sure how helpful it would be.
Gearing the prop to allow a smaller prop perhaps as Stephen - Prosper,is doing ?
Anyway good luck with it.
John
Mark.
Quote from: OZPAF on Aug 29, 2026, 03:09 AMThanks for the explanation Mark.
John
No problem John. It will make more sense when you see it anyway. I agree, having the pitch adjustable would be an interesting complication. Having looked at the intricacies of the variable pitch hubs, I think I'd be into uncharted territory too. The pitch changes when the motor torque has reduced sufficiently, and that's done using springs or a torque bar. I would have to experiment with different spring rates to obtain the required movement, so in this instance, I'm more than happy to give it a swerve!
I'm not sure plastic gears would survive very long from the motor in the Hurricane tbh. Prop will be quite a good size - coming in at 19" diameter. I'll be attaching the blades using strimmer wire as well for an element of 'crash proofing'.
Interestingly though, even with a prop that large, it didn't look ridiculously oversized when we offered one of Ivan's (many!) props up.
Prop hub is made and utilises bearings i am also using the prop shaft for a F1B/Wakefield. 3mm in diameter running on the roller bearings makes for a nice front end. I'm also using the Piserchio hook at the rear and F1B/Wakefield parts up at the front end. Ivan uses this sort of setup on all his big scale models, so I've chosen to follow this path as well. I'm always a bit of a sucker for some nicely cnc'd aluminium parts! 😂
OZPAF
QuoteI'm not sure plastic gears would survive very long from the motor in the Hurricane tbh. Prop will be quite a good size - coming in at 19" diameter. I'll be attaching the blades using strimmer wire as well for an element of 'crash proofing'.
Hmm! Yes I agree - bit of an oversight on my part.
Thanks again for all the info on your interesting project.
John
Prosper
Quote from: OZPAFGearing the prop to allow a smaller prop perhaps as Stephen - Prosper,is doing ?
I can't imagine the forces generated in the powertrain of a model this gigantic, but surely they'll be hefty, with a capital h,e,f,t and y. Now, that's not to say that Medieval Europeans said - Oh, like we can't like build these like, yeah, windmills, because we've only got these plastic gearwheels from China . . . in other words there must be a 'gearing solution' for a 1/10 scale Hurricane to be had - but a daunting project, maybe . . . Also to consider is that with gearing where the prop turns faster than the motor, the rubber motor will be bigger (thicker) than for a direct-drive setup - so even more heft required . . .
Picture: suggestion for suitable winder for your model.
Stephen.
