Members
Stats
  • Total Topics: 382
  • Online today: 35
  • Online ever: 247 (Jun 15, 2026, 07:31 PM)
Users Online
  • Users: 1
  • Guests: 5
  • Total: 6
  • Jmk89
Recent topics
1960s Coupe d’hiver postal comp
Started by Jmk89, Dec 28, 2025, 11:39 AM
Previous topic - Next topic
billdennis747
Looks nice. Don't put it in those trees; I've never seen a wood-coloured model before!
cvasec
dputt7
   Thanks for the video Tim, now I don't have to describe just how good it flew. It really did fly straight off the board.
THB
Thanks Jeremy - yes trial-and-error likely to be the best option.
Mike - thanks for your advice with the prop - I'm a single-blade convert now - half the work! No real lift about that morning - too early/cold. Polish designer Juliusz Jaronczyk claims "Coffee" will do 105secs in still air on 6 strands of Pirelli rubber, 6 × 1 mm, wound to a maximum of 320 turns. Mine has 6 strands 3/16in SuperSport. (I do have have some Pirelli - but it is long ago reduced to a crystallised form... I keep it out of nostalgia / a need for authenticity / hoarding issues.)
Bill - Thanks. With the name 'coffee' I couldn't resist doing it in coffee colour. When summer arrives the model will be exactly the colour of our larger field - brown soil and straw grass :-) Dave seems to be able to find his scale models painted in German splinter camouflage in bushland, so I'm up for the challenge!
Ron & Dave - thanks - yes very pleased with the floaty glide. We just need now to get some official flights in for the postal over the next couple of months!
cheers
Tim
Jmk89
Quote from: THB on Aug 01, 2026, 12:26 PMI'm a single-blade convert now - half the work!
The issue that gets a lot of people about the single-bladed prop is the balancing.  As well as static balancing (making sure that the counterweight holds the blade horizontal at rest), there is a dynamic balancing issue caused by the blade creating  thrust and the counterweight not doing that. While there are theoretical/mathematical ways of calculating this effect and trying to work out the rearward bend in the counterweight arm that will correct for this (there's an article by Martyn Pressnell that calgoddard has referred to elsewhere on HPA 3), the May 1942 issue of AeroModller has a jig to empirically determine the correct angle.  I attach a pdf of the AM article
All the best
Jeremy
Better drowned than duffers, if not duffers won't drown
Jmk89
Here's a pdf of the Martyn Pressnell aricle
All the best
Jeremy
dputt7
I remember going through the single blade folder balancing when I built a Pinocchio and then again when I built another after the first was lost on it's fifth flight ;D
THB
Thanks Jeremy - Mike sent me a copy of the Pressnell article but I had not seen the Watson/Aeromodeller one! Dave's Pinocchio(s) never seemed to have balance issues - good to know the theory.
Cheers
Tim
steve-de24
Thanks for the articles - very interesting.
If you are going to replace a two bladed prop with a single bladed one, are there any rules of thumb regarding required changes in blade area, diameter etc.? TIA Steve.
G GRELL
Hi All I am a little behind but there is now 2 months left for the southern hemisphere to put in there flights for the coupe postal Hope the weather is with you have a great time flying
Glenn
