Members
Stats
  • Total Topics: 460
  • Online today: 30
  • Online ever: 484 (Oct 19, 2026, 11:51 AM)
Users Online
Recent topics
My Hatband replica build
Started by Jmk89, Oct 04, 2026, 08:35 AM
Previous topic - Next topic
Jmk89
I got on with the tail feathers today.
Fin
The fin is made in one piece, even though it looks unlike other fins on John's models. His typical fin is a rhombus on top and another as an under fin, with the whole thing made in one piece and attached through the fuselage.  The one piece construction does make the fin a bit more structurally resilient.
However, the photos of Hatband seem to have a perfectly square upper fin, and a rhombus under fin, with the latter set a bit further back.  However, I decided not to abandon the one piece construction method.  So the TE of the upper fin is the spar for the under fin. and there are solid parts that match the lines of the upper and lower longerons.  I think I will use 1/16" to sheet the area where the fins go through the top and bottom of the fuselage so I get a solid fin attachment.
First I laid out the 1/8" square parts of the structure.  The lower outline and the spars are medium density and the rest is soft.
Then the 1/32' x 1/8" diagonals are fitted in.
Once dry, it will be sanded flat on both sides and the outline will be rounded over.
Tailplane
First step is to shape the LE and TE (including 1/32" deep notches in the TE for the straight ribs) and glue the LE, TE and curved tips together.
Then the straight (3 x 1/16" and 8 x 1/32") ribs and the diagonal ribs, which were sandwiched out last night were removed from the isopropyl alcohol that they soaked in overnight and were laid out to dry.
All the best
Jeremy
Better drowned than duffers, if not duffers won't drown
Jmk89
Tailplane (cont)
Last step today was to glue in the straight ribs.
Tomorrow the diagonal ribs will go in.
After that, prop, prop assembly and nose block and pylon to do.  That might not be so speedy - clients are asking me to do legal work for them.  Don't they know I have important model building to do?
Then covering.  I wonder if I should ask whether mylar under tissue is allowed.  It isn't an aerodynamic improvement, but rather a technique to improve the durability of the tissue covering.  Any weight advantage makes no difference for a model in a class that has minimum weight rules.
All the best
Jeremy
Jmk89
All the airframe has been completed so the last few days' work has been making the noseblock, prop blades and prop assembly.
For this, I followed the directions in JOD's Better Propellers articles (especially article 2).  Since this can be obtained easily from the Plans Gallery at https://hpa.aeromodelling.gr/plans/details.php?image_id=2204
I( won't clutter up the thread with a repetition of the information you can find there.
Here's a photo of the prop in the pitch jig with the attachment wires being epoxied to the blades.
The orange thing in the vice at the bottom of the photo is a piece of 125mm PVC pipe with sandpaper attached - although JOD says he doesn't use undercamber on his prop blades, there is about 2% of undercamber in the ARAD 6% airfoil that I like to use and the pipe makes a good sander to achieve that undercamber.  I hold the blade at about 15° to the left and sand  the blade along that angle - it reduces the amount that you have to roll the blade to put the undercamber in the right place ( this is really an adaptation of the method used when making props by moulding them on a tin can or bottle).
The wood is not balsa but paulownia - because I have it and it is nice to carve.
All the best
Jeremy
OZPAF
That is an interesting way to add the undercamber Jeremy. I imagine you won't need to glass the prop since you are using paulownia.
John
Jmk89
Quote from: OZPAF on Oct 24, 2026, 02:05 AMI imagine you won't need to glass the prop since you are using paulownia.
John
I will use fibreglass to reinforce the hub wire to blade joints (as JOD wrote) but the blades generally will just have tissue covering
All the best
Jeremy
OZPAF
Jmk89
Felt a bit better today, so I got on with some more work on Hatband.
The prop assembly is almost finished - just a washer to solder on to the shaft behind the noseblock and a prop hook to bend.
Also worked on the rear fuselage so that the fin can be fitted through the fuselage as one piece - a typical JOD technique.
The relevant spacers had to be removed and then two 1/16" sq pieces placed 1/8"apart glued in lengthways so the fin is centred and straight.
This is the upper side:
  • arrow 1 is the gap where the spacer has been removed
  • arrows 2 and 3 are the additional lengthways pieces to support the fin.
This is the lower side:
  • arrows 1 and 2 are the gaps where the spacers have come out
  • arrows 3 and 4 are the lower additional lengthways pieces to support the fin
Here it is all dry fitted.
All that I need to do now is to put in and glue the replacement spacers between the outside of the lengthways pieces and the longerons.  I was feeling tired so I stopped then - I need fresh eyes for that job!!!
All the best
Jeremy
Jmk89
I remembered something else I needed to make for Hatband - a pylon for the wing to sit on and to get the fuselage cross-section up to the required area.
The pylon skeleton is all made from 1/16" medium balsa.  The centre piece slopes from TE up to LE to give 3° +ve incidence and the cross pieces match the centre panel dihedral angle (also 3° each side).  The thing to the right of the pylon skeleton is another 3D printed sanding block.  This time it is to sand some soft balsa to fit the wing lower surface curve.
Here's another picture of the sander.
I used it to sand a piece of soft 1/4" balsa to match with the wing centre section lower surface. This becomes the top section of the pylon.  I used a 2" x  4 1/4" rectangle and once I had the surface sanded to fit nicely with the wing lower surface, I cut it in half lengthways and sanded the centre sides of each half to 3° using the same sanding block I made to sand that angle onto the LE, spar and TE.
Then I propped the two pylon top pieces at the correct angle and glued them along the centre line.
Finally, I glued to top onto the base skeleton.
Next cut the
All the best
Jeremy
Jmk89
Now to finish the pylon we cover the outside with 1/32" light balsa with grain vertical.
First side sheet covered.
Second side ready to be covered.
I added some 1/4"x 1/16" medium balsa underneath the spar so there is a full depth lateral surface so the wing sits solidly on the pylon.
All the best
Jeremy
Jmk89
Time to finish off the fin attachment.
Two sub-spacers (arrowed) for top slot.
Four sub-spacers (arrowed) for bottom slot.
Fuselage ready for covering.  The fin is just pushed into the slot and the pylon is just sitting on the fuselage.  The pylon, fin and fuselage will be covered separately.  After covering, the slot will be cut out and the fin glued into the slot (the trim tab will be stuck on the fin then, too).
As for the pylon, it won't be glued in place until the correct CG is located.  Until then it will be held onto the fuselage by rubber bands.
Finally, the fuselage with prop in place as well.
Now I'll have to contact G GRELL to see whether tissue on mylar covering is allowed.  So don't expect any major progress on this project until I hear back from him
All the best
Jeremy
Jmk89
Apologies to Glenn Grell, I had a senior moment and couldn't remember his first name, so I used his HPA handle.
All the best
Jeremy
dputt7
   Hi Jeremy,  Your pet project is coming on very nicely, a reward for your all your research. How is the weight going, I find Coupes a struggle for my clumsy fingers.
Jmk89
#27
In uncovered state the weights are:
Fuselage (inc. fin and pylon) - 20g
       (Pylon is 5g, so if the weight is too much, I can carve some out of there!)
Prop assembly - 24g
       (Blades are paulownia - I could save some weight if I went to balsa blades, I suppose, but paulownia doesn't               soak up dope like balsa, so the finished weights may not differ that much)
Wing - 11g
Tailplane - 2.6g
TOTAL say 58g - so 22g for covering, dope and rubber.
So it may be a 100gm rule coupe ;D
All the best
Jeremy
Jmk89
I suppose I could save a gram or two by losing the hold pin!
All the best
Jeremy
