Members
Stats
  • Total Topics: 485
  • Online today: 43
  • Online ever: 484 (Oct 19, 2026, 11:51 AM)
Users Online
  • Users: 0
  • Guests: 14
  • Total: 14
Recent topics
Prop Quick Change Adapter
Started by _shadow_, Nov 16, 2026, 05:27 AM
Previous topic - Next topic
_shadow_
Guys,
I had this idea sometime back, experimented with it and it seems to work. The only drawback is the weight of the metal pushrod connector.
The photos with the prop show uncut prop shaft.
This 'system' allow for quick prop change to try out different P/D ratio.
Regards
M
OZPAF
Interesting - does the small grub screwed collar hold under full winds?
John
_shadow_
It does as I have used it on peanuts only, nothing larger. Have to admit that it's not implemented on all of peanut models, but just one.
Regards
M
lccjaw
Here's a solution we tried back in the late 1980s. Thought up by a fellow modeller called Peter Fosdick.
You just unhooked the front a slid on a new prop. A five second pit stop! The suggestion was that you soldered the coil but I used cyano to fix it as I didn't want to risk melting the nose bush. It worked fine but the wire bending was a bit of a challenge and it didn't catch on.
_shadow_
Quote from: lccjaw on Nov 19, 2026, 01:19 PMHere's a solution we tried back in the late 1980s. Thought up by a fellow modeller called Peter Fosdick.
Nice! I like this very much! Thank you.
Regards
M
dputt7
Thanks iccjaw that is so simple. It could be used to select the correct prop on a new model then a "normal" prop shaft with a freewheel device could be fitted.
OZPAF
That's clever Iccjaw. I tried a freewheel system that used a drive dog behind the prop - coiled as you have shown and soldered onto the shaft. It worked ok but eventually the soldered joint (only soft solder) broke, which was annoying as it had allowed for prop changes.
I'm a bit surprised that the CA made a strong enough bond.
John
