  • Total Topics: 485
  • Online today: 27
  • Users: 0
  • Guests: 8
  • Total: 8
Adjustable Nose Bearing for Peanuts
Started by _shadow_, Nov 18, 2026, 04:21 AM
_shadow_
Guys,s in mind, i.e. an adjustable nose bearing for peanuts.
I've seen some implementations which were quite simple, so I put this into CAD, still work in progress.
The center cylinder is the prop bushing, the prop shaft will run through, the larger outer cylinder with the cone shape inner wall, the outer diameter would be about 8mm, the length about 10mm, the flat plate with the slot would enable side and up/down adjustment. Still need to figure out some other stuff to enable a max of 5deg of thrust angles.
I'd like to see how others have solved this.
Regards
M
Piecost
Interesting idea, is there a risk of the sliding plate being damaged in a crash? Perhaps aluminium rather than 3D printed plastic might be more resiliant?
It is similar to what I implimented on a peanut Bristol Scout, where the large round cowl allowed plenty of space to impliment.
The plastic bearing is a loose fit into a hole in the ali cowl and is held at the back by two ali clamps. I thought that I was very clever in inventing this idea. But, it has been around for a while and is clearly shown being made on Maxfliart's Youtube channel.
On a peanut model with less space I use a ply washer behind the propeller bearing, with a shim. This is standard practice except that I premade a number of them to varying width. I replace the whole washer and shim rather than fiddle with sanding or gluing on extra thickness.
The shims never seem to stay glued when I attach them during the flying session. I suspect that the gluing surface gets contaminated with rubber lube.
The thrustline is set by a cocktail stick peg, which can be moved into a number of different holes.Screenshot_20261118_033217_Gallery (1).jpg
Both methods seem to work and survive crashes.
I have used the K&P adjustable bearing, but find it a little fiddly.
CF-EKM
Hi,
I reply to your question from IIFI  thread here.
The shown bearing was made for peanut and larger models.
I created several designs since 2022, first from 3d printed resin. Nice method (could produce 80 pcs. from one print) but too hazardous process and material too brittle. I flew this type  in my first pistachio.
Then I moved to FDM print, no chance. Quickly I quit with 3d printing and changed to machined aluminum.
That was the right decision. Had to play around with how the bearings are set and finally there was a reliable system so I could produce them.
First batch was about 25 bearings.
Me and a few friends fly them since 2024.
This bearing has some nice pro's:
Double ball bearing with a large bearing base so the shaft runs very precise.
Axial thrust from rubber is supported by the front bearing, very low power loss here. Power loss from sideforce from rubber is very low.
Adjustment is intuitive and precise.
Right thrust and downthrust are adjusted independently of each other.
You can make smallest adjustments within seconds.
The adjustment mechanism is self-locking. The propeller bearing never changes its setting.
Installation dia. of the bearing is 11mm, weight about 0,75gr. Thats im many cases less than you need to add  noseweight for trimming the CG.
The integrated version has a flange dia of 19mm, weight 1gr. This was design to purpose, a prototype.
Installation dia. will reduce to somewhat 15mm.
The bearing can be mounted forward with adjustment screws accessible dirctly, if model has no spinner cap.
Or inverted with the adjustment screws behind the motor head for scale, spinner etc. In this case there is a extended shaft housing to avoid a long, unsupported propeller shaft.
This bearing is not the ideal solution for every use-case. And personally I admire more the other, individual solutions people make. Because this one is machined, thats not so much supporting the spirit of craftmanship.
But it was a nice development project and it works.
Currently we (Matthias and me) plan to produce a new batch with some improvements in machining. First batch I made on my own, alone. Now with his help we'll jump in this topic again and produce some stock.
CF-EKM
Some views of the "standard" version.
I also tried PTFE bushìngs instead of ball bearings. Not satisfying, too much friction.
Ball bearings from china (1x3x1) not suitable as inner race is 2-part design, they cannot take any reasonable radial loads (but the rubber creates reasonable loads from rubber-to-shaft angle and from the rubbers dynamic forces).
So I went to expensive japanese ball bearings and use the chinese bearings only to extract the inner race which gives a perfect load-transfer ring between prop and front ball bearing.
Currently we're discussing about alternative materials and how to set the ball bearings but I feel there is no good reason to change material just to change it. As 1st, weight is quite low already and 2nd, aluminium is very rigid compared to plastics.
Probably we will just optimize the design to improve the universal character regarding installation in the model.
_shadow_
#4
Quote from: Piecost on Nov 18, 2026, 05:55 AMInteresting idea, is there a risk of the sliding plate being damaged in a crash? Perhaps aluminium rather than 3D printed plastic might be more resiliant?
Thanks for sharing this, the double metal flange looks very interesting and idea of using plywood, perhaps the lite version, would probly work better, and it would glue well too.
Defintely aluminium would be much strong, but fabrication would be an issue to an average modeler, 3D printing would be much more accessible.
Indeed, Maxfliart is a source of inspiration to me as well.
Regards
M
_shadow_
Christian,
Thank you very much for the details explanation. Weight is my main concern but getting the device to hold it's setting is also another issue along with it being smooth.
I have these, but I forget the maker or it's proper name, got them more than 10 years ago. The concept seems similar to what you have come up with.
Regards
M
CF-EKM
#6
These are good.
I remember that "Gizmo Geezer" uses a similar principle.
What drove me developing my own design is the fact that with a 120° configuration (3 screws), any adjustment inevitably results in a combination of side thrust and downthrust—depending on how the adjustment screws are positioned relative to the model's main axis.
In contrast, a 90° configuration (4 screws) allows for the adjustment of side thrust independently of downthrust.
For aircraft with a long nose—such as the Pilatus Turbo Porter—weight is a significant factor.
Most other models, however, require ballast in the nose.
I am satisfied with a total weight of 0.75 g for the entire mount. I won't be reducing the weight any further (0.55 - 0.6 g would be possible).
For a 3D-printed bearing the design shown should work quite well.
In my experience, PA6 is a good material due to its excellent layer adhesion and elasticity...it's unbreakable.
PA6CF would likely be ideal for the housing (better stiffness). As for the shaft bearing itself, a shrunk-in brass tube might be a good choice.
lincoln
Quote from: _shadow_ on Nov 19, 2026, 05:37 AMChristian,
Regards
M
I have seen something like that made by John Regalbuto, though he's no longer with us. I think he also made a gadget for counter-rotating props.
It's actually possible to use three screws and adjust only the down thrust or only the side thrust. Imagine you have screws at 0°, 120°, and 240°. To adjust side thrust, turn the 2nd screw +n and the third +n turns or degrees. To adjust downthrust, turn the first screw +n and the other two -0.5n.
You can use four screws, but then you need to make sure that there is no play and that you aren't crushing anything.
Instead of shims, you can use little machine screws, maybe countersunk. If you have a subject with a radial engine, you can put the screws a bit further apart and use the dummy engine as the nose plug. Small rare earth magnets can hold it against the screws. If the retention with flathead screws is too strong, and you don't have smaller magnets, use round head screws and a counterbore, or scotch tape spacers. This is the system on my Seversky racer, a veteran of many mass launches, and a relic of the 20th century.  It may be resurrected some day. The mice did a real job on it.
_shadow_
Lincoln,
Could you please share a photo of the system in the Seversky race?
Thanks!
Regards
M
