  • Total Topics: 483
  • Online today: 60
Short S.42 1912 monoplane
Started by Pete Fardell, Dec 28, 2025, 09:11 PM
Pete Fardell
Big thanks to George for getting this forum up and running here. Great effort!
This is my latest indoor scale project, started when I came back from the IIFI feeling inspired to start on a new Indoor Nats model. It'll be 25" inch span,1/16 scale for rubber.
It's a Short S.42 which was very much based on the Bleriot XI, the main difference being it had a beefier undercarriage that dispensed with the Bleriot sprung 'bedstead' system. It was flown in the early days of the RNAS by the legendary Charles Rumney Sansam.
Some pics and two 3-views can be found here: https://flyingmachines.ru/Site2/Crafts/Craft28639.htm
Mine is based on the drawing from the Putnam book:'Short Aircraft since 1909'by C. Barnes.
(The other drawing on that webpage is from the Peter Lewis Putnam book:'British Aircraft 1809-1914' but to my eyes it's not quite as accurate as the other one.)
I only have the makings of a fuselage so far, with quite a lot of rigging done in the open section. I'll be using the same aerofoil as on my Bleriot, as plotted for me by Toon Verbruggen.
Squirrelnet
Great subject Pete I shall look forward to following this one.
Hopefully this will some of the wonderful flying characteristics of your Bleriot, the fuselage is looking pretty good already . Interesting that the Short appears to be a larger aircraft than the Bleriot given the different scales between your two models. I had always assumed it was more of a copy but clearly not
Pete Fardell
Sorry, should've said 1/14 scale, not 1/16. Span of original aircraft was 29' 3".
Pete Fardell
I now have wings! I used the same Toon Verbruggan aerofoil as on my Bleriot, which is quite drastically undecambered and a bit of a faff to make as none of the spars can be laid flat on the board. Done now though, so hopefully the effort will be worth it. Tips were laminated round a form.
The tailplane on this aircraft was also undercambered. I'm not sure how closely to replicate this on my model. I suspect such lifting tailplanes are a bit of a pain when it comes to trimming so am tempted to tone it down a bit, or maybe even flatten it completely. Does anyone have thoughts or experience with this?
TheLurker
Quote from: Pete FardellThe tailplane on this aircraft was also undercambered. I'm not sure how closely to replicate this on my model. I suspect such lifting tailplanes are a bit of a pain when it comes to trimming...
I built the Mooney peanut one with a reflex tail as per the plan, but didn't get enough intact landings out of it before I gave up repairing it to be able to tell whether or not I should have gone for a flat tail. However the flights it did make were quite... swoopy which suggests to me there was an up elevator effect giving a climb / soft stall cycle.
I may be able to tell you more when I finally finish my "big" Chiribiri, see pic. :)
cvasec
Why not use the same section as you did on the Bleriot. You know it worked!
Ron
Prosper
Hi Pete,
Very nice, clean, accurate woodwork! I always enjoy your builds.
Stephen.
Pete Fardell
#7
Quote from: cvasec on Jan 11, 2026, 12:41 PMWhy not use the same section as you did on the Bleriot. You know it worked!
Ron
My thoughts too. The real Channel Bleriot had a more or less flat tailplane though, so although mine is of thinner section I didn't have to worry so much about it looking unscale. I think it'd be more obvious on this one.
 I think I might do it flat and put 'cheat ribs' at each end to sort of suggest a bit of undercamber.
Spiros (Spyros)
Quote from: TheLurker on Jan 11, 2026, 10:57 AM
It's a masterpiece! Very clean job!! Bravo!
Squirrelnet
QuoteWhy not use the same section as you did on the Bleriot. You know it worked!
Ron
Sounds like a good plan. My co2 Bleriot had a lifting tail but it has a modest undercamber rather than the deep undercamber you can see in the photo's. I think you are right to compromise on the section and you know the Bleriot one works
Pete Fardell
Thanks for the thoughts on the lifting tail. I really both Lurk's Chiribiri one and the Brainwood Bleriot's. However, I've now built mine with a flat underside and just a bit of camber on the top. Hopefully it won't misbehave.
I've also made the tailskid and rudder. I'm slightly worried the rudder is a bit small, but it is to scale dimensions. It would be a very quick job to make a larger one though, so I'll leave it for now.
Pete Fardell
I've made the wheels now too using a patent  "lolly stick" method which worked out rather well. The stick was removed after the first round of spokes were threaded on, then I cut more grooves in the rim and added another lot of spikes to fill in the gaps. Just two lengths of thread were used for each wheel.
Pete Fardell
Tyres are just rings of 1/32 balsa stuck together and glued onto the rims.
They still need painting of course, but here they are in situ and also a mock-up shot of all the bits now made. Dummy engine next.
TheLurker
I didn't know Sir Michael Caine built model aeroplanes.  Live and learn, live and learn.
Squirrelnet
Oooh that's looking very evocative already. Wheels look great too
