News:
Main Menu
  • Total Topics: 485
  • Online today: 43
  • Users: 1
  • Guests: 15
  • Total: 16
  • malc
Bellanca Bellonian
Started by g_kandylakis, Jan 16, 2026, 12:02 AM
g_kandylakis
It was back in 2012, the good old SFA was then still the main active forum for most free fight modellers.
Cookups were pretty common at the time. So, at some point Roman Groener suggested to organise one for Bostonian models. I do not remember how many people participated. Maybe Roman can.
What I do remember though is that in the end it was my own designed "Bellonian" which won the cookup and the prize donated by Roman, a Swiss Army knife.
The Bellonian was a carricature model of the Bellanca WB2 "Columbia", which flew two weeks after Lindbergh over the Atlantic, from New York to Berlin. It only made it to Cottbus, slightly short of Berlin. The history behind the two flights is a most interesting and intriguing one. Suffice to say, Lindbergh initially wanted to use the Bellanca for his flight but Juseppe Bellanca did not agree, probably not trusting a young inknown pilot for such a feat.
The model has been flown very much the following years, in Greece but also in Germany and Switzerland where I was living for a number of years. Especially in the Swiss Olten meetings it had quite an adventurous career with high long flights and some tree landings.
After acummulating enough damage I decided at some point to repair/rebuild it. This was helped by the fact that I never managed to retrieve one wing from a tree. If I remember correctly, I posted the repairs in HPA, a few years back.
So, it kept on flying. Until last Sunday all was well, when it unexpectadly met a wall in our gym and then crashed nose first to the floor. Nothing new or major but the nose did come off (in pieces). So, being in the process of repairs once again, I thought I 'd post the pictures from the original thread of SFA.
g_kandylakis
So, lets take it from the start...
February 2012
fin and rudder structure, 2mm thick balsa
g_kandylakis
fuselage sides and box. Quite a fatty one.
Again balsa 2mm
g_kandylakis
The nose block was carved from thick balsa and then hollowed out. The struts were a worry with so much mass so soft balsa was chosen.
An interesting looking frame
g_kandylakis
covering time.
Silver tissue was chosen for the fuselage and tail, white for the wings. The silver was a bit of a failure, as the pigment proved sensitive to the thinned dope
g_kandylakis
the fuselage cowl would prove impossible to cover properly with all those double curvatures. So it was sealed with multiple coats of dope and then sprayed with the closest looking aluminium lacquer paint.
The wing registration letters were done with black tissue paper, the rest was drawn and printed on waterslide decal paper.
g_kandylakis
fummy engine cylinders, wing struts with a lifting airfoil, also sprayed.
g_kandylakis
cowl painted
dummy cylinders glued in place
g_kandylakis
Final assembly. April 2012
Alignment by eye mostly, using anything that was available and heavy enough
g_kandylakis
#9
and the finished model, looking quite pristine at the time.
Logical, flying had not started yet
g_kandylakis
#10
and on the green floor of our gym. Last picture, with the Swiss Army knife prize won for the cookup, sent by Roman end of May. Accompanied by, what else, a Swiss chocolate bar. Better than the knife
g_kandylakis
#11
And some early test flights
and more
g_kandylakis
The model was flown extensively in the various swiss outdoor meets, as already posted. It surely appears in some videos made by rubberfly, I 'll have to search.
Well, that didn't last long, did it...
Fast forward to October 2022, one crash too many, or one tree landing too many. I wonder wher the other wing is.
g_kandylakis
new wings built, covered, registration letters cut and glued, again
g_kandylakis
