  • Total Members: 376
  • Latest: Andrew
  • Total Topics: 481
  • Online today: 68
Scale Towline Gliders
Started by bcarter1234, Jan 29, 2026, 12:53 AM
bcarter1234
About an hour's worth of work brings the fuselage to this stage.
bcarter1234
Another beautiful evening for towline gliders. The Baby Albatross is ready for paint.
I'm so glad this always happens when my planes go in a tree.
bcarter1234
The wing halves are cleaned up and glued to the center section. Tail feathers are next.
bcarter1234
Fin and stabilizer ready for gluing.
gravitywell
Gorgeous lines on that bird.
bcarter1234
A couple pictures of the Nemere and Baby Albatross. Both are ready for paint.
bcarter1234
The modified Nemere is a real floater. The extra chord makes a huge difference. The model has 108 inches of wing area, a scale wing would have about 74.
bcarter1234
A nice fly over of the Baby Albatross. I learn more every time I go out.
Prosper
bcarter1234
Thank you Stephen.
36" wingspan, 72 square inches of area, approximately 1" chord at the tip.
What do you all think, tip stall or turbulence?
Subsequent flights went fine.
lincoln
Those are great. Have you tried wet sanding? It might be easier on your lungs.
My favorite sailplane web site, where I've spent many hours: more sailplanes than you can shake a stick at
https://www.j2mcl-planeurs.net/
bcarter1234
Lincoln,
I haven't tried wet sanding but I will. I've noticed the dust bothers my eyes for a few hours after a shaping session so it probably isn't doing my lungs any good either. One of these days I'll not start a new glider and actually put some paint on one of these.
I recently found that website, what a great resource.
bcarter1234
Instead of starting a new glider I spent a little time painting one. The paint added 9 grams which isn't a lot unless taken as a percentage. Then it is a whopping 33% increase. I'll try airbrushing the next one to see how difficult it is, if it looks better and if it is lighter. The biggest issue with airbrushing is getting tape to stick to this foam. It seems to actively reject the adhesive in 3M tapes. It isn't that it doesn't stick well, it will curl up off the surface. I'd love to gloss clear this but the weight penalty makes that prospect unappealing. If I can get masking sorted letters will be added otherwise this is likely all it will get. I want to try simulating the wood structure underneath eventually.
bcarter1234
Quick and dirty but is should look okay in flight.
Piecost
Very nice. Thanks for the update
