  • Total Members: 357
  • Latest: ChrisH
  • Total Topics: 437
  • Online today: 45
Scale Towline Gliders
Started by bcarter1234, Jan 29, 2026, 12:53 AM
lincoln
Some interesting subjects for small scale gliders:
Motiekaitis Moti-2 PLENTY of wing area:
Moti 2
Oskinis BrO-3 Moderate aspect ratio:
BrO-3
Note that there were at least 2 versions. See also the BrO-4 and -5, which would be interesting subjects too.
Castel-Mauboussin Jalon.  Reasonable aspect ratio.
Jalon
IS-4 Jastrzab. AR is 12
Jastrzab
I had better quit now. There are many other interesting possibilities that have wings which are not impossibly skinny. One of the 1930's American air racers was turned into an airshow glider, but I can't remember the name. I'm not sure that it's on the site above. If you like flying wings, consider the Horten Parabel or the Hutter IMI. Both are on the above web site, and the former is on nurflugel.com as well.
bcarter1234
lincoln,
I'll take a look at those tonight. I was actually considering a Horten 4 but I'm also tempted to do a primary glider next. Not efficient but fun to watch.
bcarter1234
lincoln,
I particularly like the IS-4 Jastrząb. On my short list is Stakhanovets which also has a swept forward wing.
https://www.j2mcl-planeurs.net/dbj2mcl/planeurs-machines/planeur-fiche_0int.php?code=765
I have to admit though, for the most part sailplanes with high aspect ratios draw my attention. The 36" Reiher seems to work okay even the the tip chord is only 25mm.
bcarter1234
The Nemere flew at least a dozen flights this evening. These things are addictive.
bcarter1234
bcarter1234
The 36" La Pruvo is started. The fuselage blank is ready for shaping. AG04 airfoil wing cores were cut with no washout as it seems the forward swept wing should not need it. The tail surfaces were slightly enlarged and the fuselage extended about .5" to get a TVo of 0.65
I'll of course have to eat some takeout to get foam for the tail surfaces.
With nearly 140 square inches of wing area and a thinner foil I'll experiment with ballast to see how it affects stability and flight duration. If it works the ballast could be replaced with a rudder servo to allow higher launches on the small field.
Lastwoodsman
Scale Towline Gliders      Wed April 1 2026
Hi Lincoln and bcarter1234.  I tried all of those links above and I only got a blank page.  Is anyone else getting the same as me?  :-\    The videos work but not the links.
Lastwoodsman
Richard
bcarter1234
They worked before but aren't now. Go to this link and search for the sailplanes lincoln mentions by name.
Lastwoodsman
Scale Towline Gliders         Thurs April 2 2026
Hi Brent:
     I really liked Lincoln's reply where he went to all the trouble to make a very appealing post,  with the little introductions of each of four gliders,  with their specific links.   It was very cleverly done,  and I remember thinking at the time:   "Great ....,  now I can easily check out these four recommended gliders".     But yes,  the links are currently still not working.
     I know that the window for editing a post,  is long gone,  so maybe you can get George to update those failed,  original direct links,  for everyone's use.   And re-post those links also,  in the latest comments too,  so people can be able to see it.    Direct links really are the cat's meow,  and the greatest thing since sliced bread ....   8)
     This topic is too good to have links that do not work ....
Lastwoodsman
Richard
bcarter1234
Getting closer to being ready for initial test glides. I saw a Swallow tail kite while I was out skating today, now I want to build one as a glider.
lincoln
Argh! The computer ate my homework. Here is a link to a page about Petras Motiekaitis, designer of the Moti 2. It has a link to more info on the Moti 2:
Petras Motiekaitis
The following page has links with info to the BrO-3, -4, and -5. It also has many other interesting links.
LithuaniannAviation
Andante
My first attempt to FF scale gliders was a Kit of a Slingsby Cadet, kit from West Vings or Aerographics.
Built 10 years ago and after some help to get a good trim it made an impressive maiden competion flight.
A viewer who him self was a full scale glider pilot screemed "Ingvar! Don't adjust anything - it flies better than the original.
Since few years I have a real scratch project - a Bergfalke II built as I think in Sweden and got it's air worthy certificate in 1959. SE-SXA. Can be seen in Borås Segelflygklubb, usually hanging in the ceiling to save space for more frequent/daily flewn gliders. The first 2 sets of wings was discarded. The present pair is built not as the original - instead like we usually build model airplane wings and have a slight undercamber.
The project is awaiting energy to build the fuselage with it's impressive fin (that needs to be a bit oversized compared to the original)
Cheers / Ingvar
Andante
I have found that gluing with classic balsa glue has several advantages, The Slingsby got a what looked like to be a lethal damage due to very moist conditions last year and seamed to be beyond repair, however 6 months rest in it's paper box had stiffend the construction and some repair gluings could be unglued after tedious wetting with acetone (like a full hour).
Test gliding in the garden was very promising and it managed to do some fair flights in completely dead late evening air.
Cheers / Ingvar.  I have added an avatar - the photo was taken 1955
Jmk89
Quote from: Andante on Jul 10, 2026, 12:00 PMI have added an avatar - the photo was taken 1955
What a handsome little chap!
Maybe we should all find a suitable childhood photo to use as our avatar?!
All the best
Jeremy
