  • Total Members: 376
  • Latest: Andrew
  • Total Topics: 481
  • Online today: 55
VMC Fokker D VIII
Started by TheLurker, Dec 27, 2025, 11:06 AM
Spiros (Spyros)
I will try to.
Being my first CO2, not sure if I would be of any good to others... ;D  ;D  ;D
Definitely will regularly add some updates
TheLurker
g_kandylakis
#17
Hi Lurk,
It looks promising and definitely good in the air. And one piece in the end is always a good result
3/4 of a circle at Trinity, that sounds at least safe...
Looking forward to videos in the next time.
A quick question/request:
can you please give us the following weights;
Model weight with no nose assembly, no rubber no rear motor peg. The basic model.
Nose assembly as is.
Balast in nose assembly.
The reason...
Spiros already stated he wants to make it as a CO2 powered model and I am trying to figure the overal parameters of the model...
Thanks,
George
TheLurker
#18
Quote from: g_kandylakis on Jun 21, 2026, 06:12 PMLooking forward to videos in the next time.
Aye, well. If it survives trimming. :)
ΓΚ> Model weight with no nose assembly, no rubber no rear motor peg.
22.7g
ΓΚ>Nose assembly as is.
12.3g
ΓΚ>Ballast in nose assembly.
Additional ballast is carried in the hopper just behind F0 and at the moment it's 1.3g.  The "fuselage" weight above does not include this.
Bear in mind
1 - The tail assembly on mine is formed outlines rather than the kit sheet parts.
2 - I made up a balsa cowling for the motor rather than use the kit supplied part.
ETA.
The nose assembly includes a Knight Aero MK II adjustable nose block, the new "Lego Brick" style.
g_kandylakis
Thanks Lurk!
Forgot to ask about the rubber weight...
Spiros (Spyros)
Hi Lurk.
Many thanks for the data!
TheLurker
Quote from: g_kandylakis on Jun 22, 2026, 12:19 AMThanks Lurk!
4.5g
A loop of 3/16", 12.5" (31cm) pre-tensioned so probably about 13-14" (32.5 - 35cm)plain loop.
Spiros (Spyros)
Lurk, short question.
On the upper front part of the fuselage you added balsa instead of paper. This is also my intention.
Did you do this also on the sides?
TheLurker
Evening Σπύρο,
I used paper sides.  I did consider balsa cladding, but I couldn't see a good (i.e. simple & lightweight) way of doing so and still being able to fit the wings & struts.
Because I decided to use paper I cut some 1/32" stand-offs to reduce the risk of the sides becoming concave in use as had happened with my VMC Sopwith Camel.
The other thing I tried was to make a couple of very small stops for the wing struts to make it easier to fit them in the correct location at finally assembly.  It worked rather well.
1    - Strut stop prior to trimming.
2, 3 - Stand-offs
4    - In position
Spiros (Spyros)
Τέλειο!!!
Perfect!! Thank you very much. Everything is clear!
TheLurker
Quote from: TheLurker on Dec 27, 2025, 11:16 AM...If you do build one of these make sure the tail skid is /firmly/ fixed in place, especially if you try and trim over a hard gymnasium floor.  Peter Smart's build of this lost the tail skid inside the fuselage when the tail banged down.
And as I found out earlier this evening while doing a bit of pre-Trinity checking the tail skid has gone on mine too. Mine has snapped at the entry to the fuselage.  If you build one of these for indoor use it may be worth your while looking for a slightly stronger alternative to the kit part. If you're only ever going to fly yours out of doors there's almost certainly no need to bother.
I'm going to try a bamboo replacement and see how that goes. I won't be surprised if have to try something else. :)
TheLurker
Olive needs a new wing. One with more than scale dihedral.
Today's session at Trinity showed that even with the celluloid shrouds on the spars it rolls and has a tendency to unexpected, and very undesirable, changes of direction.  On the plus side it did manage to complete almost a whole circuit. :)
Unfortunately I was too stupid to photocopy the kit rib sheets before I started building so need to speak to VMC about another kit.  Do that Monday and hope they've got one or two on the seconds pile.
Prosper
Quote from: TheLurker. . . One with more than scale dihedral . . . even with the celluloid shrouds on the spars it rolls and has a tendency to unexpected, and very undesirable, changes of direction
I made a D.VIII once (2014), with scale wing sections (thick flat-bottomed centre-section going to heavily-concave undercambered tips). 14" span. It's the only scale model I've ever made where abrupt tip-stalling, with "unexpected . . . undesirable" consequences, was a show-stopper. Looking at the photo I've just dug out . . . . I wonder if the prop diameter relative to model size, could have been a factor. I've been pondering a rubber-powered geared-prop D.VIII with small prop.
Stephen.
Jmk89
Quote from: TheLurker on Sep 12, 2026, 10:27 PMUnfortunately I was too stupid to photocopy the kit rib sheets before I started building so need to speak to VMC about another kit.  Do that Monday and hope they've got one or two on the seconds pile.
I would be tempted just to use your favourite flat-bottomed airfoil. The VMC airfoil is unlikely to be an accurate scale one, so Clark Y is as authentic as any  ;D
All the best
Jeremy
Jmk89
Selig's Incomplete Collection of Airfoil usage lists the DVIII as using Goettingen 387 and his other site gives the following picture
and co-ordinates:
GOE 387 AIRFOIL
       17.       17.
 0.0000000 0.0000000
 0.0125000 0.0308800
 0.0250000 0.0452600
 0.0500000 0.0645200
 0.0750000 0.0787900
 0.1000000 0.0905500
 0.1500000 0.1065800
 0.2000000 0.1181000
 0.3000000 0.1276500
 0.4000000 0.1262000
 0.5000000 0.1167500
 0.6000000 0.0998000
 0.7000000 0.0783500
 0.8000000 0.0539000
 0.9000000 0.0279500
 0.9500000 0.0144700
 1.0000000 0.0000000
 0.0000000 0.0000000
 0.0125000 -.0186200
 0.0250000 -.0217400
 0.0500000 -.0249700
 0.0750000 -.0272100
 0.1000000 -.0279500
 0.1500000 -.0274300
 0.2000000 -.0259000
 0.3000000 -.0208500
 0.4000000 -.0158000
 0.5000000 -.0122500
 0.6000000 -.0087000
 0.7000000 -.0061500
 0.8000000 -.0046000
 0.9000000 -.0030500
 0.9500000 -.0025200
 1.0000000 0.0000000
I reckon that at 13" wingspan, it's close enough to flat-bottomed!
All the best
Jeremy
