  • Total Topics: 483
  • Online today: 60
  • Users: 1
  • Guests: 15
  • Total: 16
  • bjrn
IGRA Jodel Bebe
Started by Pete Fardell, Mar 16, 2026, 08:42 PM
Pete Fardell
This will, hopefully, be my Kit Scale entry this at the Indoor Nats. It's a Jodel Bebe from the Czech IGRA kit: 24 inch span. I plan to do it in the same starry scheme as Jiří Doležel's recent Pistachio version. And thanks to Jiří I now have two photos of F-PEVE instead of just this rather blurry one I found online.
The question is though, can I "do a Banham" and build it in two weeks? This would mean I could try and trim it at the pre-Nats Bushfield meeting on 29th March.
Pete Fardell
Now covered and starrified. Still a bit to do, but I still hope to test it at Bushfield on Sunday. (I was sooooo tempted to swap the V for a T on that reg! ;D )
Squirrelnet
Really nice Pete. The stars look great, I would not have thought of painting the tissue before fitting them  ( which I've just realised you only said in your Facebook post 😂)
Pete Fardell
Quote from: Squirrelnet on Mar 27, 2026, 08:32 PMReally nice Pete. The stars look great, I would not have thought of painting the tissue before fitting them  ( which I've just realised you only said in your Facebook post 😂)
Thanks, Chris. Yes, stars cut from yellow tissue pre-sprayed both sides with yellow acrylic to make them opaque.
g_kandylakis
"Sweet dreams"...
Nice one, Pete!
As for the registration, you should have done it, perfectly legitimate...
George
OZPAF
Eye catching scheme Pete. That was quick!
John
Anyun
Twinkle, twinkle little star, this Jodel-build has come far
Up above the earth you'll fly, starry diamond in the sky
Twinkle, I must say at last, Pete does surely build quite fast
Nice model and best of luck with the trimming! /Andrea
Pete Fardell
Thanks for the nice comments.  :)
Here are a couple of pics now that the noseblock's been painted and the dummy engine finished and affixed. And here's a rather distant video of the last of its test flights at Bushfield last Sunday; this after a LOT of assistance and advice (and catching!) from one R. Crossley. Getting it to turn without dropping a wing was the tricky part, but I think it's nearly there.
Trim tabs, tip weight and a long motor wound up a lot.
I should have started further over. Richard caught fur me several times that day which meant it came home undamaged.
OZPAF
Fair bit of potential there Pete. R. Crossley would make a good cricket fieldsman  :)
Good luck with it.
John
Lastwoodsman
Jodel Bebe by Pete Fardell   yellow stars on blue plane
Hi Pete.                             Wed April 8 2026
Very eye catching color scheme there Pete.   I see a big sun in there too.
Scintillate scintillate,  globule orific.
Fain would I fathom thy nature specific.
Loftily poised in ether capacious,
Strongly resembling a gem carbonaceous.
Lastwoodsman
Richard
Pete Fardell
Some more indoor test flying with this one today, over at the Norwind indoor meeting at Rochdale. It's much more amenable now that I've increased tha wingtip dihedral as per the advice of Graham Banham.
Thanks also to Ian Lever for filming the last of these three flights for me.
Pete Fardell
#11
Back from the IIFI with the Jodel now, so here's the lowdown on its fortunes there...
Its first trimming flights at the hall in Wijchen on Saturday were, frankly, disappointing. It seemed to have misplaced its Rochdale trim somewhere in the North Sea and now wouldn't take off at all, trundling around with its left wing touching the ground. Help, however, was at hand in the form of Jiri Dolezel who, having himself done a beautiful pistachio version of the very same aircraft (see first pic) seemed very determined to help mine fly well. I'm extremely grateful to him. Every (very precise) suggestion he made helped instantly. Sheer Czech magic! The first main change was to put an up-tab on the right wingtip's TE, and remove the down-tab I had on the left (inboard) wing. He also put a 5mm shim of extra right thrust in the nose and soon things were looking up. The trouble was that, until Jiri eventually cured it, the turn opened out at the end of several test flights and I kept breaking off the tail in the resulting wall collisions. This then needed repairing and as it wasn't usually a very clean break the repair affected the trim each time.
In the contest it managed a poorish but safe enough qualifier in round two though, and then on Sunday made some real progress in the pre-round trimming session (again all thanks to Jiri's input) to the extent that by the time round 3 was announced I was quite confident of a good flight. This it managed, except that it was a bit on the low side. Last round then: more turns, and real hopes of an excellent finale. It did get higher and looked great. Unfortunately, however, it couldn't QUITE clear the wall as it made its last turn, so it lost any landing points. It was a very nice flight otherwise though. The wall contact was my own fault for starting it too near the same wall on take off, but I can't be too hard on myself; it's always a difficult call for me and I started it there in order to avoid it finding the wall on the other side (where of course it had plenty of room to spare as it turned out). Ah well- that's indoor FF for you! It finished 10th out of 15 in the end (you need two good Kit Scale flights in IIFI rules, not just one). I'm slightly hoping that when I see the full scores I'll find that I wouldn't have made the podium even with a good last landing, but in any case I'm sure the flyers occupying places 4-9 have similar "oh so nearly" stories to tell!
All in all though, a very satisfactory first indoor contest for the Jodel. I'll add any of its IIFI flight video links to this thread when they appear on YouTube.
I shall probably try the model again at the  Velodrome's NW Gala in February and possibly at the Indoor Nats in April as well.
Pete Fardell
Sorry, that should have said a 0.5mm shim of right thrust was added to the nose. Not a 5mm shim!
