News:
Main Menu
  • Total Topics: 485
  • Online today: 43
  • Users: 0
  • Guests: 29
  • Total: 29
Zlín Z-50 M
Started by Jiri Pavlicek, Mar 20, 2026, 10:06 PM
Jiri Pavlicek
This is my first topic in this forum. Currently Im building Zlín Z-50 M in peanut scale. Im decided reposted this project to this site, if it's not a problem. Im building model based Lubomír Koutný plan with some modifications.
This picture shows which marking I chose:
Jiri Pavlicek
The first off all fuselage and tail. Medium hard balsa for fuselage and light but strong balsa for tail..
Canopy made from thin plastic film
Jiri Pavlicek
Building of wing and details of canopy, spinner and tail.
Elevator is covered by japenese tissue.
OZPAF
Very nice build.
John
Jiri Pavlicek
Rudder covered by japanese tissue.
Jiri Pavlicek
The wing will be covered as two halves. For this reason, it was a good idea to additionally strengthen the root rib so that it would not collapse under the tension of the covering.
All additional adjustments are harder and take longer for me.
I made a template for the ribs from the drawing, then a plywood template according to which I cut the ribs. I fitted and glued them with CA and then sanded and polished them. Hopefully it will hold its shape!
Jiri Pavlicek
I split the wings in half and made holes in fuselage for spars..
Now she has wings!!
Squirrelnet
Really nice build Jiri, enjoying following this one
Jiri Pavlicek
Quote from: Squirrelnet on Mar 21, 2026, 09:45 PMReally nice build Jiri, enjoying following this one
Thank you very much!👍🏻
Small detail on front of fuselage. It's only on the port side...
Jiri Pavlicek
Only small progress..
I don't know how to write it in English correctly.
Rubber hinge or holder? 🙈
It's 1,5 mm bamboo stick.
dputt7
#10
Nice work, The rear mount for the rubber is called lots of things but I just call it "the rubber peg".
TheLurker
Quote from: dputt7 on Mar 22, 2026, 03:57 PMNice work, The rear mount for the rubber is called lots of things but I just call it "the rubber peg".
Agree, lovely work and another common name is "motor peg".
OZPAF
Hi Jiri. Koutny's plans have always impressed me and your work is very good - what modifications did you make?
John
Jiri Pavlicek
Thank you very much for your kind words!
Jiri Pavlicek
Quote from: OZPAF on Mar 23, 2026, 12:35 AMHi Jiri. Koutny's plans have always impressed me and your work is very good - what modifications did you make?
John
Thank you John.
I made many modifications...
Airfoil, dimensions by the real pictures, mainly wing incidence
