Members
  • Total Members: 321
  • Latest: DeanI
Stats
  • Total Topics: 358
  • Online today: 24
  • Online ever: 247 (Jun 15, 2026, 07:31 PM)
Users Online
Recent topics
GYPSY MOTH DH 60 DUMAS KIT 336 RUBBER POWER PARK FLYER 30 INCH
Started by Lastwoodsman, May 21, 2026, 06:41 PM
Previous topic - Next topic
Lastwoodsman
GIPSY MOTH DH 60   DUMAS KIT 336  RUBBER POWER PARK FLYER  30 INCH
Mon June 29 2026       Reply #45     post 1 of  3
Camo Wing Design
Pic #1     3648     Five patterns are copied,  cut out,  and are ready to overlap and fit to the outline.
Pic #2     3651     Here they are on the big board.
    Here are two repeating outline patterns.
Pic #3     CAMO STENCIL OUTLINES  1
Pic #4     TIGER STRIPE CAMO PATTERN
Lastwoodsman
Richard
cont
Lastwoodsman
Mon June 29 2026       Reply #46     post 2 of  3
Camo Wing Design
     I took some time off yesterday,  and did some relaxing searching around the internet all day off and on.
     I discovered more Camo color schemes to consider,  by typing in these search bar words ...
Seamless repeating camo pattern
fluid outline blobs
fluid liquid flow shapes
blue camo vector
camo pattern templates
camo layered stencil
camo coloring pages
camo outline
camo print outline
camo drawing
Pic #1     SEA BLUE GRAY CAMO
Pic #2     BLUE CAMO HIGH RES
Pic #3     BLUE CLOUD REPEATING PATTERN
Pic #4     LIGHT BLUE SEAMLESS PATTERN DIFFERENT SIZED CLOUDS
Lastwoodsman
Richard
cont
Lastwoodsman
Mon June 29 2026       Reply #47     post 3 of  3
Camo Wing Design
Pic #1     3698         This is a striking blue repeating digital pattern,  overlapped on the Building Board.
Pic #2     3703     The digital pattern is now on the Big Board.
Cloud Patterns
Pic #3     3709     Two   'Cloud'  seamless repeating patterns,  one expanded more than the other,   are on the big board at the bottom.
Pic #4     3711     The new Cloud 1  and  Cloud 2 designs, are cut out for the wing shape,  and pinned to the big board for comparison.
Lastwoodsman
Richard
Lastwoodsman
Mon June 29 2026       Reply #48     post 4 of  4
Camo Wing Design
     Here are my top three choices for camo topped wings:
Pic #1     3713     Cloud 1  and   Cloud 2  seamless repeating camo designs,  have been cut out,  overlapped,  and pinned to the Big Board,  for comparison.
Pic #2     3719     These are the three practice finalists for the blue camo design.    They are all cut to size,  overlapped and pinned to the big board,  and clear taped together.
"Light Blue Camo"  is my original in the middle.
Cloud  2  from the net,  is on the top.    Cloud  2  looks a little bit  'busy' .
Cloud  1  from the net,  is on the bottom.    Cloud  1   looks more ...  like it is actually floating in the "puffy"  cumulo nimbus clouds.
     Heatwave has started here in the middle of the Great Lakes of North America,  along with our  'jungle'  humidity.   Now,  3:00 PM,   it is  89 deg F  (feels like 99 deg F).   High of 90 deg F today.    Humidity is 57% now,  but will be  85%  by morning.
Lastwoodsman
Richard
Lastwoodsman
Wed July 1 2026       Reply #49
Fresh Sandpaper
     We got out all of the sandpaper blocks and stapled on fresh  100  150  220  sandpaper.   To fold around the blocks properly,  the  'creases'  in the sandpaper were first slightly scored with an awl.    Actually,  all of my sandpaper cuts were made with several strokes of the awl,  using the long clear,  cm and mm scale,  Safelex Shatterproof Helix rule,  30 cm  300 mm long.   File folder cardboard was used as a cutting mat.
Pic #1     3730     Cleaned off the building board.
Pic #2     3734     Sanding blocks to freshen up.
Pic #3     3737     All new sandpaper.
Pic #4     3743     I just used staples to hold them together.
     Now we are ready ...
Lastwoodsman
Richard
Lastwoodsman
Thur July 2 2026       Reply #50
     This is going to be an enjoyable build  -  I can tell right away.  :)   All of those tiny laser cut holes in the balsa parts are all  3/64"   0.047"   1.8 mm.    These holes are for the rigging and control wires !   8)  And the kit has very comprehensive rigging wire diagrams and instructions.   This is a very modern kit that was released in 2016,  and now ten years later,  Dumas has,  unfortunately,  closed up shop.   :(
Pic #1     3747     All of the big long wing copies and files etc.  are pulled off of the Big Board,  and stored in the long  'Gipsy Moth Plan Copies'  folder(s) above the Big Board.
Pic #2     3749     Note the tiny holes in the balsa parts for the rigging wires,  and for the control wires,  holes and slots.
Pic #3     3751     My notes are written on the plan,  in pencil.
Pic #4     3752     The Landing Wires,  and the Flying Wires are not labelled in this pic,  but they are labelled in Pic #3.
Lastwoodsman
Richard
Lastwoodsman
Fri July 3 2026      Reply #51
More progress on the fuse side frames.
    That was a lot of difficult round head pin pushing  -  especially pushing through too many layers of waxed paper ...
Pic #1    3753    The fuse side frame has been finally located and securely blocked up in place.  The  1/8" sq longerons and other frame pieces have been cut out and fitted.
    I lightly drew in little vertical guide lines,  on the longeron  1/8" sq balsa,  to guide the edges of the three main vertical pieces,  of the fuse side frame.  "Little things".
Pic #2    3757    Vertical guide lines for Part B1 at Station 1 front nose.
Pic #3    3758    Vertical guide lines for Part B3  rear motor peg plank  Station 7.  The guidelines are actually straight -  they look off because of the camera angle ...
Pic #4    3761    Vertical guidelines  for Part B4  rear tail end vertical support  -  call it Station 10
    I almost forgot.  I also need to add the new,  more forward,  rear motor peg plank support,  at the front of Station 5,  (for equal rubber on both sides of the C of G Center of Gravity).
Lastwoodsman
Richard
