News:
Main Menu
  • Total Members: 376
  • Latest: Andrew
  • Total Topics: 481
  • Online today: 68
Dewoitine D.520
Started by livingroomflight, May 27, 2026, 02:44 AM
livingroomflight
And two more photos  ;)
Spiros (Spyros)
Really nice outcome. What is the wingspan?
livingroomflight
Thanks! Wingspan is 13 inch, standard peanut.
Cheers,
LRF
Spiros (Spyros)
Ok. I tried to figure out why you complained about the weight.
However, I think it should fly just fine. It's not only a matter of weight but motor (rubber) you will be using.
livingroomflight
Sure, it will fly just fine, but will it make the magic 60 sec that mark the project successful?  ;)
I doubt that, but I'll do my best and will keep you posted!
Cheers,
LRF
dputt7
  Vert neat. Good luck with the trimming.
TheLurker
#21
Quote from: livingroomflight on Jun 24, 2026, 07:21 PM....18g without rubber. ... using 3 strands of 1/8...
You may be right but I think I'd start with a simple loop of 1/8" (0.125") and only add the third strand if that proved inadequate.  A couple of my peanuts are around the 15-16g mark without motor and are fine on a loop of 3/32" (0.094").
Nice looking model.
Cheers,
Lurk
livingroomflight
Thanks dputt7, TheLurker!
Thank you for sharing your experience.
In my case, I could never get a decent speed and climb on a low winger peanuts with a loop of 3/32. Even the lightest ones performed way better with 1/8. But I know, a lot of good fliers are using 3/32 including some famous ones, so surely I am doing something incorrectly.
Anyways, will go with the power gradually and will indeed start with a loop of 1/8.
Cheers,
LRF
Sky9pilot
Outstanding work! Your craftmanship is much better than you give yourself credit for. Your tissue work is great!
Sky9pilot
livingroomflight
Thanks Sky9pilot, happy you like it! :)
Best,
LRF
sandfac
Beautiful build, LRF! Good to see you on the forum, and your planning and tissue work is certainly paying off.
Oliver
