News:
Main Menu
  • Total Topics: 485
  • Online today: 43
  • Users: 0
  • Guests: 29
  • Total: 29
Dewoitine D.520
Started by livingroomflight, May 27, 2026, 02:44 AM
livingroomflight
Hello,
I started this a bit before I discovered this forum. So the bones are almost done.
Cheers,
LRF
ramses
Very nice bones!
Are you going to paint it or use coloured tissue?
Cheers, Ramses
livingroomflight
Thanks!
I am going for the tissue camo.
Yesterday I did start covering the stab. It matches fuselage OK and leaves
some room for trimming.
For covering, was using diluted white wood glue to join tissue pieces.
Once dry, I ironed it and glued to the stab using the same glue.
Then after it dried out again I took care of the edges. Then I wet it and fixed to the piece of wood to stretch overnight. That was quite some work for that and it was just a stab. Fuselage will be funky ;)
Cheers, LRF
ramses
Quote from: livingroomflight on May 28, 2026, 10:17 PM...Thanks! I am going for the tissue camo...
Very nicely done!
Beautiful work!
Cheers, Ramses
Spiros (Spyros)
Very beautiful! Congratulations
ZIP.58
A delicate model with an interesting color scheme. Great work—congratulations!
Peter
Anyun
I like your technique joining tissue pieces of different colour. I once tried something similar but failed, perhaps because the tissues I used were of different types with different shrinking characteristics. You seem to have found a working method!
Best of luck with the build of your nice little Dewoitine!  /Andrea
OZPAF
That's pretty impressive work.
John
livingroomflight
Hello fellow modelers,
I had a bit of time and did some covering work. I was never
doing this type of technique of tissue camo before.
It's OK as for a first try. Yeah overlaps are visible, but it is what it is.
Some pics from the process.
greetings,
LRF
OZPAF
Clever and very neat. I guess it was time consuming but it will be very light!
John
g_kandylakis
Interesting approach and quite a good result! And very light.
Utrecht... Have you been to IIFI in Nijmegen or am I missing something? Because I do not recall seeing models finished like that there.
Just curious...
George
livingroomflight
Thanks guys!
Yeah its time consuming indeed.
No, I have never been to IIFI, maybe one day :)
So for this project, I framed the canopy and attached stab and fin. As for my poor building skills I am happy with the results :)
Lastwoodsman
Thur June 11 2026
Dewoitine D.520 French Fighter
Hi livingroomflight.   The overlapping camo tissue covering looks grrrrreat !!   8)
Lastwoodsman
Richard
Spiros (Spyros)
The outcome is really nice!
livingroomflight
Hey guys,
This is the outcome. It weighs 18g
without rubber. I think it is a heavy brick as for its wings area, and will be using 3 strands of 1/8, the only rubber I have. Probably a loop won't be enough.
Its very windy this year here, but once I will be able to test it I will update this thread.
Cheers,
LRF
