News:
Main Menu
  • Total Topics: 481
  • Online today: 58
Lozenge scheme for printing
Started by Spiros (Spyros), May 29, 2026, 11:23 PM
Spiros (Spyros)
Dear All,
I'm trying to find Lozenge scheme as a picture, that I could use to print an A4 page.
Currently I want to test by printing the scheme on a tissue and then experiment on methods of shrinking, doping etc.
Does anybody have an idea where I would find such schemes? Even if it is not Logenge, still a side view of a fuselage or wing (any scheme) would be good for trying.
Many thanks
Best regards
Spiros
Tim Horne
#1
Hi Spiros, Mike Stuart covered this on his website some time back. Try looking here.
https://www.ffscale.co.uk/page4e.htm
Jmk89
The Australian War Memorial collection has three pieces of lozenge fabric from WW1 and has given the colours used their colour numbers.  Here are two (no photos, but some interesting information) :
https://www.awm.gov.au/collection/C111049
https://www.awm.gov.au/collection/C110687
There are also two articles in Aeromodeller - November 1957 and May 1958 - which may help (both issues available from the HPA Plans Gallery)
All the best
Jeremy
Spiros (Spyros)
Dear Tim , Dear Jeremy,
Thank you both!!! Exactly what I was looking for.
I'll try to post a couple of results, if are any good.....
Already three models for IIFI 2026 and my head is spinning for a fourth....
Spiros (Spyros)
And of course, I HAD TO DO IT!.
I think the experiment went well......
The printing was on a white tissue, using an inkjet printer.
The printing was surprisingly good. (Pic No1)
So on the test.
First corner was water (for testing the shrinking) and it was ...... bad. (Pic No2)
However, on the next corner, I used Clou thinner which I use for covering the model (after applying the Clou dope). Perfect. No change on colors (Pic No3)
Third corner was Clou itself which in any case is applied on the balsa. There was a slight matt change on the colors, but obviously this will come back again from the final finish. (Pic No4)
Fourth corner! I applied the dope which is 50/50 dope with nitro thinner. This is for shrinking and finishing as well. Absolutely no problems too. (Pic No5)
Center. Pure alcohol. Perfect result too. Therefore can be used for shrinking! (Pic No6)
Most probably this method is well known to most of you but that is my first time and I'm thrilled!!
Spiros (Spyros)
Jmk89
That's a very satisfactory outcome, Spiros.
BTW  another useful source is O G Thetford's 1943 booklet, Camouflage '14-'18 Aircraft which has a good colour plate of lozenge camo.  I scanned my copy of this and put it up on the HPA 2 Plans Gallery and I went to put it up on the HPA 3  Plans Gallery, but before I did it, I had a look at it.  It shows that over the last year I've learned quite a bit about making better scans.  So, I re-scanned it and uploaded it to the Plans Gallery.  It will be available once George reviews it.
All the best
Jeremy
Spiros (Spyros)
Thank you so much Jeremy!
I will check it once it's available
g_kandylakis
Spiros (Spyros)
Thank you George!!
So second part of the experiment, so far seems to be working.
I made a side of a fuselage, to test in practice.....
Picture 7 & 8 is the construction
Picture 9 is the application of the tissue, gluing it with dope and nitro
Picture 10 is the result of the covering
Picture 11 is the application of pure alcohol for streching.
Once stretched (might need a second application of alcohol), I will apply the finishing. Hopefully by tonight, as I want to follow the approximate timing as in normal construction.
Spiros (Spyros)
Spiros (Spyros)
The final result after application of one layer of finishing, which is 50/50 dope with nitro thinner.
The surface and the looks are very satisfactory. It seems that there were a couple of spots on the surface but I'm not sure if these were from the alcohol or from brushing hardly on the tissue.
Still for myself, this is a green light to use it if the whole process is done correctly and not have fat finger (like my self that opened a hole on the side..... ;D , hardly noticed on the pic).
Mike Thomas
Very classy. Looks like a stained glass window. Mike.
Spiros (Spyros)
Thank you!.
Indeed it looks like a Vitro Glass....
Squirrelnet
That looks very nice Spiros, great job
