  • Total Members: 375
  • Latest: Bayeux
  • Total Topics: 479
  • Online today: 89
Humbrol Tiger Moth
Started by Piecost, Aug 04, 2026, 02:39 PM
0 Members and 2 Guests are viewing this topic.
Piecost
I was concerned about the use of vacuum formed polystyrene on the finished model. So I made a trial nose to test the following;
1. How well the plastic attaches using canopy glue
2. How well (unchalked) yellow Asuka covers the different colours of the white plastic and balsa
3. How well chalked Asuka covers the different colours of the white plastic and balsa
4. Does pre-painting the plastic and/or then balsa before tissue covering help?
5. Does the tissue cover the double curvature of the plastic without wrinkles?
6. Does wallpaper paste work Ok. The stuff made from powder and water.
7. Is the plastic stiff enough to withstand the tissue shrinkage?
Conclusions, so far
1. The 0.25mm plastic is stiffer than the soft 1/16" sheet fuselage sides. On one side the plastic glued reasonably flush. The other the plastic was proud. I cut and reglued the plastic. Perhaps the moulding was too wide. A small overhang was Ok since the plastic could be sanded. If underflush then lightweight filler could be used. The canopy glue stuck Ok, but may notnsand well.
More will be answered as I progress...
Reproducing the vacuum formed parts has been a knightmare and has trippeled the build time of this project. I am not even happy with the neatness of the moulds.
The photo shows the nose with aluminium tape holding the rear part of the plastic onto the fuselage side and household DIY lightweight filler applied to the joint.
The inset squares on the balsa side are to simulate the inset strips on the empenage. To find out how prominant they appear under the tissue after sanding.
The nose has been given local areas of lightweight filler and a couple of coats of Sand'n'Seal. This fills then grain nicely.
Piecost
The test piece has been painted with 50% thinned Tamiya acrylic. The paint does not reduce the contrast between the plastic and balsa. It may even enhance it, due to their differing textures.
I have applied yellow chalk pastel onto some yellow Asuka tissue. I will cover half with chalked and half with unchalked and tissue and see how they compare.
pb_guy
It looks like it is the grain of the wood that shows through the lighter colour paint, which is acting more like a heavy stain than paint. Perhaps a layer of thin white or yellow tissue overlaying the wood, then sealed and painted might overcome this transparency. But that does add a bit of weight.
ian
Piecost
I have now added the yellow Asuka tissue, as Ian suggested. One side is chalked and one is not, as shown in the photos. It was attached with wallpaper paste and is yet to recieve a coat of Pledge acrylic floor polish to seal and waterproof.
Initial conclusions prior to the Pledge coat:
The first conclusion is that the chalk is very subtle. It is hardly worth doing. But I will persist since I have specifically bought chalk for it.
The paint on the white plastic prior to tissue covering significantly helped it match the balsa. Definately worth doing.
Painting the balsa yielded a slightly deeper colour. This can be seen at the nose, in the photos. I am not decided whether to paint the sheet balsa areas.
If I do; I have no idea if it is better to paint the balsa before applying the tissue or to simply paint the covered model as per normal practice. I am not seeking a perfectly opaque finish, but for the plastic, balsa and open framework areas to look uniform.
I will see if the coat of pledge makes the tissue more transparent and changes the conclusion.
Piecost
I have read that doping chalked tissue can give a change in colour. The tissue become more transparent and the colour of the chalk becomesnnore prominant. This did not happen when I sprayed a coat of Pledge. I am very happy with the result.
Piecost
Success at Last with the Vacuum Formed Parts
I follwed the advice by dputt7 and implimented the following changes:
1. I made 2 new vacuum frame to fit plastic of A5 and A6 size. I could get one A5 and of two A6 from an A4 sheet of Plasticard.
2. I made a new vacuum bed to match the frames and achieved a much better seal than I had achieved with the plastic plates.
3. I added spacers under the moulds so that the vacuum pulls from underneith
I still needed to resort to the hot air gun in one place, but I was happy with the result. I even moulded two parts from a single sheet.
I anticipate needing to rework one of two moulds to fit the plastic to the fuselage better. But, at least I have a reliable process.
g_kandylakis
You can also try to lift the plugs a bit. 1 cm or so ...
Will pull better but there is one disadvantage. Plastic will pull bellow them so you will have to free them every time you mold.
But they pull better
George
OZPAF
That's a good reward for perseverance.
John
dputt7
  Glad it worked, looks good, Well done.
OZPAF
What did you use for suction? It seems quite powerful - good draw and even pulling into the suction holes.
John
Piecost
John,
I used a Shark upright vacuum cleaner. I understand thay a few years ago the Uk limited the power of domestic cleaners. This is one of them. So, not really powerful.
The 0.25mm and 0.50mm Plasticard were cooked in the oven at 200 degrees C for a few minutes until the plastic drooped slightly.
Tim
OZPAF
Thanks - it has worked really well.
John
gravitywell
Why on Earth would the government limit the suction of a vacuum cleaner?  Thats bizarre.
Piecost
They limited the power of the motors. Yes, it is really petty.
Andrew D
For what it's worth...
This is my vac form setup.  I don't have many holes, or any seals at all.  The frames are made from aluminium angle and corner brackets from screwfix, and you clamp the material between the flanges with bulldog clips as normal.  The lower angle locates around the bed so the material is essentially flush with the bed when the vacuum is applied.  I heat the material in the oven for a few minutes, quickly get it positioned then bang on the vacuum.  I can plus one on standing off the plug from the surface of the bed. This is a 3D printed plug for the VMC Fokker EV, and produces excellent results.  I got good results too with this set up for the canopies for the VMC Lysander which were pretty large and deep.  On the Fokker plug You can see the stand offs and also some though holes which made the hole locations and "centre pips" very well defined in the final moulding and also allow the full effect of the vacuum at the top of the plug.  Nb the large holes in the plug are to just reduce the amount of material used when 3D printing.  As George said you do get a bit of an undercut with the stand offs, so you have to trim the flash back level with the part to get it out.
Rome wasn't built in a day.  But then again I wasn't on that particular job.
