  • Total Members: 375
  • Latest: Bayeux
  • Total Topics: 479
  • Online today: 89
Humbrol Tiger Moth
Started by Piecost, Aug 04, 2026, 02:39 PM
0 Members and 2 Guests are viewing this topic.
TheLurker
Andrew D
Rome wasn't built in a day.  But then again I wasn't on that particular job.
Spiros
Beautiful result!! Bravo
ZIP.58
Great—that'll make for a model that flies really well. The way you're paying attention to the weight, it's bound to turn out that way.
Keep enjoying the build.
Peter
Piecost
I attach a table of weights for the different materials that I tried to make the vacuum formed parts. I include the original nose top decking. I estimated the mass of the other kit mouldings by scaling from the new parts. Estimated weights are given in square brackets.
I could not measure the thickness of the black plastic party plate because it had a dimpled surface. Scaling its thickess from the Plasticard, I estimate it to 0.18mm thick. It formed easily, but the material became too thin in places and was damaged on removal. With the exeption of the nose cowl, the thinnest plastic parts would have been strong enough on the model and would have saved a lot of weight, being only 1.7g in total.
The 0.25mm thick plastic parts weighed 2.2g but were also  damaged on removal and lead me to use the thicker 0.50mm yellow plasticard. The total mass of all the yellow parts seemed excessive at 3.5g, but was less than half of my estimation of the original kit plastic. This was a whopping 7.7g! It is not just the weight itself that is important. It is parts location relative to the centre of gravity. I could easily imagine the kits 3.8g rear fuselage decking nessesitating 10g of noseweight!
In am not sure of orignial thickness of the kit parts but measureed 0.034" on the end of a part. Since  the plastic does not increase thickness in forming: maybe 1mm was used. Maybe the thick plastic was more reliable forming. I found that thicker material less likely to split on removal from the moulds.
In hindsight; the vacuum formed moulds and parts doubled the time and effort taken to build the kit. It would have been easier and lighter to use 1/32" sheet on the fuselage top decking, as shown on the outzone plan. But, I am please to have replicated the most notible part of the kit.
For the kit; the pre-formed parts were a great way of reducing the build time and complexity.
Raggedflyer
When I eyeball the 0.25 / 0.5 mm columns the weights of the cowl, cockpit and rear items scale in proportion to the thickness. The nose item  at 0.8 g / 0.84 g is nearly the same for both thicknesses which seems odd?
Piecost
Hi Raggedflyer,
I an impressed that anyone had a close look at the data! I like to post information here as it forces me to make it understandable, in anticipation that I might review it at a later date. I don't have a strong expectation that someone will review it in detail. But, I am please if anyone does so.
I have had a second go at weighing the parts. The nose top data is now more consistent. I have included some others I found on my work bench. This gives an idea of the repeatability of those parts. However, some which split on removal from the mould were not carefully trimmed.
Cheers
Tim
Piecost
I am working on one of the worst jobs of building a biplane; rigging the wings.
I made a change to the plan in pinning as well as gluing the cabine struts to the fuselage. I want a positive location for the struts in case a later repair is needed. I employed a 0.8mm carbon rod traversing the fuselage, just behing the CO2 tank, penetrating plastic pin clamps glued to the inside of the fuselage.
I carefully set the location of the front pins from the plan. I checked their symmetry using a foamboard rigging base with the centreline and spanwise lines marked.
I made the mistake of serting the rear pin location by installing the struts and pricking through the holes in the rear struts.  This introduced a fore/aft aymmetry of over a 1mm between port and starboard sides. The photo shows that aft strut rods are nowhere near aligned. Indeed, a single rod would not go through both sides!
So, I will have to cut away one of the plastic pin clamps and reglue it.  I will position the top wing before I do so.
OZPAF
It's interesting to see how much weight you have saved with your vacuum formed alternatives.
John
Nigel_M
Using the pin clamps as a reinforcing for carbon is a great idea. I have some of the black ones but could do with a source of spares. Anyone any idea where they might be obtained now?
Jmk89
Quote from: Nigel_M on Nov 12, 2026, 08:49 PMUsing the pin clamps as a reinforcing for carbon is a great idea. I have some of the black ones but could do with a source of spares. Anyone any idea where they might be obtained now?
Peck Polymers (Wind-it-up Enterprises) lists them but they seem to be out of stock at the moment:
https://www.wind-it-up.com/collections/tools/products/pin-clamps?variant=32423029538901
All the best
Jeremy
Piecost
I made a foamboard jig for rigging the model. This seems rather overkill, but I enjoy making complex jigs and boxes out of foamboard. Also, the fuselage is not symmetric and care is needed to try to get the motor thrustline in the correct orientation to the wings and tail. At least the fuselage is the correct colour to match its banana shape!
I anticipate needing the jig in case of future repairs. The jig will support the model in its transport/storage box. The box will keep the wreckage of the original model,  along with all the moulding jigs  to keep everything in one place.
A foamboard plinth was made with the centre section of the lower wing lying flat and 90 degrees to the fuselage centreline. The fuselage was supported at the correct incidence. Slots allowed the undercarrage to penetrate the plinth. Supports are added to ensure that the tailplane is parallel to the plinth, thus with the wings, when it is glued on.
I photocopied the wing rigging templates from the plan and glued them to some foamboard. These are removeable from the base to allow the model to be held or removed.
Weirdly; I had to extend the upper wing slots forward 4mm, increasing the stagger. I am not concerned if the location of the top wing is a little forward, as long as the incidence is accurate and the wings are square to the centreline. The upper and lower wings are set at the same incidence. Nice and simple.
A removeable card jig rests on the fuselage cockpit openings to set the centre section incidence. I was pleased that the relocated rear cabine strut pin made the wing sit in aligment. Also, that the top wing naturally sits on the centre and tip supports without having to be held. I hope that this remains the case after covering and shrinking the wings i.e. that I do not introduce any warps.
The carbine struts did not need adjusting in length to penetrate their sockets in the upper wing centre section. But, I may have to make longer rear interplane struts. The intention is that the struts do not rest on the top/bottom of their sockets,  but float and will be held with balsa cement.
Piecost
I am covering the model in yellow Asuka tissue. I am chalking the tissue rather than painting it. I am not painting the balsa before covering.
I taped the sheet of tissue to a sheet of glass, rough side up. I sanded a Cadmium Yellow Faber-Castell Soft Pastell and rubbed the powder into the surface with a tissue.
I used chalked tissue on my previous peanut model and could not detect an increase in mass. So, I carefully weighed the tissue before and after application.
I used about 5mm of the rectangular bar, about 0.65g which increased the wieght of the tissue by 0.22g. So, about a third is absorbed. This increased the tissue from 13.9 gsm to about 14.8 gsm.
