News:
Main Menu
  • Total Topics: 485
  • Online today: 43
  • Users: 0
  • Guests: 29
  • Total: 29
Sopwith Triplane
Started by pb_guy, Aug 16, 2026, 02:46 AM
pb_guy
  I recently finished cleaning up a plan for a Sopwith Tripe designed by C.A. Kukuvich and published in the July 1945 issue of Model Airplane News. The plan is actually 0.3 inch larger than the standard 13" W/S because it was drawn to 1/2" to the foot in scale. If the plan is printed out at 97%, then it falls just under 13" W/S. The side view is of his model, as published.
  I decided to go with laminated wing tips and rudder outline - 1/32 x 1/16". Forms are thin cardboard with the outer edges sealed with candle wax. Half done now, half yet to go. I cut out the LE and TE parts. Now for all of those ribs!
ian
dputt7
Watching with interest.
pb_guy
Wow! That was a lot of ribs!. The inner rib ends were upgraded to 1/16 from 1/32", as were the ribs on the upper wing at the dihedral breaks. They will be glued in place after the dihedral is set. Fortunately, I have some detailed pictures of a Sopwith Tripe that I took years ago at a museum in Calgary. I will install the wingtips next after they are sanded in X-section.
  My nephew was just at an airshow, and he gave me a picture of a P-51 that he painted. (Yes, I know - no stab. Think of it as a tailless version.)
malc
Waiting with bated breath to see where you put the motor peg ;D
OZPAF
Also following with interest, Ian.
John
pb_guy
I plan on anchoring the motor peg at Former D.
ian
Kelly
QuoteMy nephew was just at an airshow, and he gave me a picture of a P-51 that he painted. (Yes, I know - no stab. Think of it as a tailless version.)
I recognized it straight away, stab or no stab. Mighty fine painting!
pb_guy
Wings sanded. Top wing center ribs to be added later. I am going to make pockets for the struts. Current weight of the wings is 2.0 grams.
ian
Jmk89
Looks very well made.
I suspect that the original plan was "light on" with ribs.  The 3-view in Bruce Robertson's "Sopwith - The Man and His Aircraft" suggests about double the number of full ribs and quite a few riblets.
This was a common feature of early flying scale models, so your model is authentic in being accurate to the original plan, but maybe not up to the standards that currently are being used in making scale models.
All the best
Jeremy
dputt7
THB
#10
I reckon if you are using more than 6 ribs per wing you're not trying hard enough to add lightness!  ;D  It's always a choice and I always lean toward getting a good flying model. Nice model and look forward to your progress - Tim
pb_guy
Thanks. There is always a limit to how close to scale construction you wish to go. There is a lot of detail in the fuselage and engine that is left out, as well as in the wing. All model construction is a compromise on appearance, weight, expense, and how many years you wish to spend in construction. This is supposed to be fun, not work.
ian
pb_guy
Fuselage sides finished. I altered the plan and fitted the cabane struts into the basic fuselage structure. It  makes attachment to the top wing so much easier. Also I made pockets for the wing struts. This is a closeup of how one looks.
ian
pb_guy
Tail feathers roughed out. Slight modifications to the sheet parts to increase the gluing area. Laminated outline added for the rudder.
ian
pb_guy
Tail surfaces trimmed and sanded. I had to add a bit more balsa where the curves were too narrow. Weight 0.4 gram.
ian
