  • Total Topics: 483
  • Online today: 60
  • Users: 0
  • Guests: 14
  • Total: 14
Dumas Citabria (Kitscale)
Started by Spiros (Spyros), Dec 28, 2025, 07:19 AM
0 Members and 2 Guests are viewing this topic.
Spiros (Spyros)
Having participated for the first time in IIFI 2025 and although my participation was less than the rookie's standards, I was so thrilled, that coming back in Greece I decided to prepare two for next year. The best one of the two, will win a ticket to Holland.
Already finished the Fuselage and tail (having changed a few balsa strips here and there), and now it's time for the wing.
TheLurker
Quote from: Spiros...having changed a few balsa strips here and there...
The pictures make the kit supplied wood look quite hard/dense.  Is it?
Spiros (Spyros)
I think it is the picture is self. They are good and some dark coloring is from the laser cut. I have already sanded a bit and obviously more before covering. No complaints so far.
Will try to make a couple of more detailed pics and post.
Spiros (Spyros)
Not sure if these pics are any better (color and brightness), but so far had no issues with the supplied wood....
Spiros (Spyros)
With the right panel ready and partially sanded, it ended up on a weight of 1,7gr.
So far, the Fuselage is 3,5gr, both rudder & stab 0,8gr.
I hope the overall weight ends up below 10gr (before covering, prop etc)
Spiros (Spyros)
So...... all in all and before final sanding, it ended up in 7.7gr below my target of maximum 10gr.
I hope I will have an overall weight of approx 15gr.
SvenH.
Awesome my friend, awesome 👏
Spiros (Spyros)
Haven't had the time in between the building of the model and all the rest going around, but in the meatime, Citabria is finished and most probably on Sunday will have the first test flight.
Some data concerning the weight: Overall without rubber 20,4gr. The wing load is 7,3gr/dm2, which is good.
Can't wait to give her a try!!
rgroener
Spiros, great looking Citabria.
The Dumas Citabria was my very first built rubber powered airplane.
Yours is looking much nicer than mine...
I am sure that she also flies much better than mine ;)
I can't blame the kit, it was my lack of knowledge and building skills...
I hope you had some nice flights with her in the meantime?
Roman
Ian_Melville
#9
Quote from: TheLurker on Dec 28, 2025, 12:01 PM
My Dumas Citabra kit was like that a few too many lbs for the size and came out heavier than I would have liked. There is also wood where I would have slimed or removed had it not been for the Kit Scale rules.
Cheers
Ian
TheLurker
Quote from: Ian_Melville
My Dumas Citabra kit was like that a few too many lbs for the size ...
There is also wood where I would have slimmed or removed had it not been for the Kit Scale rules.
Cheers
Ian
Don't BMFA Kit Scale rules allow you to substitute the wood for your own without penalty?  That would go some way to solving the problem without sacrificing static points.
