  • Total Members: 376
  • Latest: Andrew
  • Total Topics: 481
  • Online today: 55
Remember this? Avro F monoplane
Started by g_kandylakis, Sep 07, 2026, 02:16 PM
g_kandylakis
And here is something from the past...
I like to think that many of us have some models that were truly flops in one way or another.
Mine is the Avro F monoplane, built around 2012-2013, documented initially in SFA and then in HPA.
A labor of love in terms of construction and attention to detail and a complete failur when it came to flying. Never managed to trim it properly, mainly perhaps because I never bothered to do the work involved. Something must have been fundamentaly wrong to begin with, I suspect wings warped that prevented a proper turn. And other factors as well.
Before this year's BMFA indoor nationals I decided to take it along to give it another try. Upon taking it out of the box to check I was shocked to discover it had a broken tail and fuselage. I did remember droping the box one time but did not notice any damage then. So I quickly close the box and put it aside, flying my Moth Major peanut instead in Open Rubber. It did unexpectedly well getting 3rd place.
With November IIFI in Holland approaching, I decided to repair it and give it another go, so here a much shorter "repair thread" on that. There is also a parallel build going one, that will get its' own thread.
The damage was on the horizontal tail and the rear fuselage where the stab attaches. I also wanted to straighten and strengthen the wings, so this meant removing all the covering from everywhere. It would be impossible to match the paint color of 2013 today.
g_kandylakis
So, I am now in the process of recovering.
This time I elected to leave the outer wood surfaces unpainted as they will be painted over anyway. Hope it does not show through, it did not in the previous state.
And the new build on the background
Piecost
It is good to see you repair this lovely model. What are you covering the delicate structure with?
Tim
TheLurker
Quote from: Piecost on Sep 07, 2026, 08:52 PMIt is good to see you repair this lovely model. What are you covering the delicate structure with?
More importantly; what are you covering those legs with!? :)
g_kandylakis
Thanks Tim,
The structure may look delicate, being scale in cross sections but it is of basswood, so does have some extra strength.
The covering is pre-shrunk esaki.
Lurk, today we had 35 degrees outside, yesterday 38. It cools down in the evening thankfully. I knew I should have cropped that pic, saw it too late.
George
dputt7
[/quote]
[/quote]
I had similar thoughts Lurks, but at least I had manners enough not to say anything ;D  ;D
Stunthenk
In 2016 I attended the IIFI for the first time as a spectator, and I saw an Avro. (first and second pictures). The man winding in the 2nd picture, is that you, George?
I was a spectator again in 2019 and saw the same model, or another one (3rd picture).IMG_6777.JPGIMG_6797.JPGIMG_0613.JPG
g_kandylakis
g_kandylakis
Forgot to add that in the second picture it is being wound under the watchful eye of Tommy Westlin from Finland...
Covering finished now, shrinking done, doping comes next
g_kandylakis
first picture, parts drying after shrinking.
Second picture, the fuselage after two coats of dope, with the nose assembly temporary in place.
Next step is to paint everything in fabric color. Then shade painting will follow.
It will take a few days to tackle that.
g_kandylakis
Made the first step of painting today. Sprayed the base fabric color.
Masked the fuselage front first as best as I could. Last thing I wanted was a beige aluminium cabin cladding. Would have been much easier without all those landing gear legs and stuff.
The wringles are the result of slow drying acrylic paint. Took the complete night for the covering to shrink back to normal again.
g_kandylakis
That's better...
Next is some more masking, then shading and the Avro lettering on the sides.
g_kandylakis
And the rest of the parts, now dry and taught.
By next week they should be shaded for that fabric semi-transclusent effect
Piecost
Lookimg good. Can I ask what paint did you use?
g_kandylakis
