  • Total Members: 376
  • Latest: Andrew
  • Total Topics: 481
  • Online today: 55
Fokker F.VIII
Started by Stunthenk, Sep 11, 2026, 11:38 AM
Stunthenk
While working on a (hopefully) reasonable model Jupiter, my mind tends to wander and starts dreaming about next projects. With the real risk of my dreams outstripping my abilities, I started wondering about building a electric powered twin, and there is a wonderfull candidate from the Fokker stable, the F.VIII! This was designed because the KLM wanted a larger aeroplane with more passenger capacity. The design started out as a trimotor but it was realised that motors were becoming more reliable so the center motor was ommitted. This had as advantages that it was cheaper to operate, there was less noise and vibration in the fuselage, and a larger freight compartment in the nose. The structure was almost identical to the F.VII. Fortunately, there is enough information available on the internet to design a model.
First picture: H-NAED with contruction number 5041.73ce968d7293c2ce38dd5986aeafc09d.jpgjpg.jpgFokker_F.VIII_3-view.jpg Quite an elegant plane, isn't it?
Second picture: the available 3-view is not of the best quality.
Third picture: this drawing looks a lot more accurate.
Stunthenk
Colours should be no problem, as the F.VIII was featured in a comtemporary advertising poster. Designing the structure will be helped by pictures of an uncorverd airframe.eed6ae32e51fae54dabe4dd27d0a32bf.jpg0a384dfdaa529807d08fc7356017bfc8.jpge8f1abf059b07356e84902bc7dfd74b4.jpg
Stunthenk
Unfortunately, especially as I am wrestling with making a 'naked' model radial engine, the F.VIII has two! Bristol Jupiters again, the IV version. But then I discovered pictures of F.VIII's that had been re-engined later in their careers, with P&W Wasps and Wright Cyclones, fitted with Townend rings. A lot easier to replicate! One of them was PH-AED. By the way, the change in registration came about in 1929, when countries were allocated national registration letters by the FAI. Before that, H stood for Holland, completely ignoring that there was also a Hungary. And the fact that this country is called Nederland...The new letters were PH (no idea what the P stands for) so H-NAED became PH-AED.
First picture: PH-AED already with the new registration but still with the Bristol Jupiters. Note the nose cap is open for loading or unloading (go to the white zone).
Second picture: PH-AED with cowled engines. Bu are they Wasps or Cyclones? My guess is Wasp, as the shield is similar to that of the Boeing P-26 which was als powered by a Wasp.
Third picture: a side view of PH-AED with Wasps.
Stunthenk
In the bottom picture of the last installment of this series a huge amount of downthrust is visible. This was not only apparent with the P&W Wasps, but with the earlier Jupiters too. This brings me to the power for the model. I have tentatively decided on a wingspan of 60 cm, or 23 5/8 inch. This makes for a reasonably sized model and gives room for 8 cm. dia props. And I hope the power of twin 7 mm pager motors with reduction gear will be enough.
Available props from the Drone world seem to be 65 mm dia. with a pitch of either 1 inch or 1,2 inch; and 3 inch dia. with 2, 2,2 or 3 inch pitch. These props are available in both clockwise and anti-clickwise running. I tend to go with one engine clockwise and the other anti-clockwise to eleminate torgue. I would appreceate advice from experts on electric power if my expectations are correct and about what to choose.
The picture shows a Jupiter powered F.VIII with a ring cowl and the same massive downthrust.c7507666c63a740d512c5db482de4137.jpg
dputt7
Not claiming to be an expert but having built the odd multi engined electric model the Idea is to have the motors wired so that the props turn above the wing toward the tip. That means looking from the front the motor on the right turns Clockwise creating a spiral of air that tends to lift the tail allowing less downthrust bringing the benefit of more usable thrust. the left will turn anti clockwise having the same effect.
A rather nice Aircraft to model, I wish you luck with it.
billdennis747
I've never been too worried about small tail surfaces but those look really tiny.
Stunthenk
I've been studying the attachment of the engine nacelles to the wing and the fuselage, looking at the struts that are visible from the outside. There seems to be a triangle of struts of which the landing gear leg is an integral inside part (seen from the fuselage side). This assembly is connected to the fuselage side with another horizontal strut. The struts going upwards connect to two wing ribs. Another two struts go forward from this assembly to a welded steel tube engine bearer. Inside the nacelle there are more struts going forward to  support the engine bearer. Rearwards from the main load carrying assembly is a triangle of struts going to the rear of the nacelle where they meet in a point. From here another strut goes rearwards and upwarts to a wingrib. Somewhere between the main carrying assembly and the end of the rear strut, another two struts go upward and rearwards and connect to the wing at two different ribs. To translate this into a model structure I think I will need two vertical bulkheads (at the engine bearer and the main bulkhead locations) and a thin ply horizontal frame to establish the horizontal profile. Stringers can be used to flesh out this assembly. Strengtened pick-up points will need to be built into both the wing and the fuselage.
