News:
Main Menu
  • Total Members: 376
  • Latest: Andrew
  • Total Topics: 481
  • Online today: 55
Folding prop design
Started by pedwards2932, Sep 15, 2026, 01:42 AM
pedwards2932
I am designing a folding prop hub for 3D printing.  I am getting ready to do the center hub section.  Does it need to be a free wheel hub?  I am thinking that since it folds it does not need to be free wheel.
Jmk89
No freewheel required if you are using a tension stop system to trigger the fold.
All the best
Jeremy
pedwards2932
I'm hoping to get away with the wind as the rubber winds down will force it to fold.  I am designing the hub to be expandable so you can vary how wide the closure is when it folds based on fuselage width.  It will use bamboo skewers and cottage cheese cup blades so you should be able to vary the length of the prop and pitch. The picture shows the hinge point and the long part is the receiver for the bamboo skewer. When I get the hub designed then I can attach it to the shorter hinge point.  I will use fusion to make the hub all one piece
Jmk89
I think that you will find that the prop blades will fold back using just the drag on the blades arising from the forward motion of the whole plane.  However, the blades will flop around destroying the glide, unless you have a positive mechanism to stop the hub turning.
The tension system puts a spring on the propshaft between the hub and the nose block which moves the hub and propshaft forward as the tension reduces at the end of the motor run so that the front hook hits a stop (typically a screw) on the back of the noseblock.  The remaining turns on the motor has sufficient rotary motion to keep the motor hook pressed against the stop so the hub stays still and the blades don't flop about.
All the best
Jeremy
pedwards2932
I could design a rubber band retraction system for it if needed.  shouldn't be too hard
lincoln
The stop screw should stop the prop in position where the axes of the hinges are vertical, so the blades food only back, without any up or down. Usually, that may be close to a horizontal position for the whole prop.
pedwards2932
The design only allows prop to fold back and stops when fully extended
Jmk89
Quote from: pedwards2932 on Sep 16, 2026, 03:28 AMI could design a rubber band retraction system for it if needed.  shouldn't be too hard
I think we are a bit at cross-purposes here.
The spring isn't to pull the blades back, it's to stop the hub turning so that the blades trail back neatly and don't flop about.  As lincoln says, you want to stop the hub turning at the same point of its rotation so the blades fold back into the same spot and stay there during the glide.
The attached picture from AeroModeller June 1975 shows the setup for a single-bladed prop. The spring is the tensioner shown on the diagram and the screw stop is shown as a dowel stop.
All the best
Jeremy
pedwards2932
I have a test plane (Cloudbuster/Flyboy) that I am going to experiment with.  I'll try the simple design first.  This is mainly for smallish props maybe 7-8 inches or smaller.
calgoddard
Sometimes when a folding prop is stopped by an appropiate mechanism (based on tension or torque) one of the bladed won't stay folded based solely on the oncoming flow of air during the glide. This can not only impair the glide, but lead to a crash if the model is pulled right or left due to the dangling blade. A couple of years ago I posted a YouTube video on how to avoid this problem using rubber bands to fold both blades. This was not my idea, but it was developed many years ago, probably by some old time flier. Here is a link to my video:
https://www.youtube.com/watch?v=AFva2c9HE1A
Jmk89
Quote from: pedwards2932 on Sep 16, 2026, 03:54 PMI have a test plane (Cloudbuster/Flyboy) that I am going to experiment with.  I'll try the simple design first.  This is mainly for smallish props maybe 7-8 inches or smaller.
I look forward to seeing your results
All the best
Jeremy
pedwards2932
I have all the pieces done.  I need to decide if I want it to freewheel or not.  Also I may need to adjust the size of the hole for the bamboo skewer. It needs to be somewhat tight but still be able to rotate to adjust the pitch. I can easily add rubber band retracts if necessary.  As designed it meets my parameter for having adjustable hub width and prop can only fold backwards.  I plan to test it with about a 7" diameter measured from hinge point.
calgoddard
#12
If the prop is going to free wheel, there is no need for folding blades with one exception. A free wheeling prop with folding blades has the advantage that the blades will fold on landing to help prevent breakage of the blades and/or prop blade spars. However, if you round the upper edge of the nose block, this allows it to be pulled out of the fuselage on landing, which greatly reduces the chances of damage to a free wheeling prop with non-folding blades.
pedwards2932
I don't have to make it free wheel easy enough to make it lock
SP250
There will be a number of stresses and loads on the 3D printed parts from the starting/stopping torque and twisting/bending loads on the folding hinge parts.  What 3D filament material are you using to make this with?
John M
