  • Total Members: 376
  • Latest: Andrew
  • Total Topics: 481
  • Online today: 55
  • Users: 0
  • Guests: 22
  • Total: 22
Digital Torque Meter - NFFS 2012
Started by _shadow_, Nov 13, 2026, 04:54 PM
_shadow_
I made this in 2012, an article was featured in NFFS 2012.
https://www.freeflight.org/complete-symposium-contents/
Posting the build photos here for reference.
Regards
M
_shadow_
Build photos.
_shadow_
Build photos.
_shadow_
Build photos.
OZPAF
That's a neat use of a small digital scale M. It appears to still read force and not torque. Do you use the force/weight readings as a guide only or use a conversion chart?
John
_shadow_
John,
You're right that the scale itself only reads force but the trick is the lever arm...the extension that presses on the load cell is exactly 1" long in this application to be read as oz/in (or make the extension as 1 cm for a g/cm).
The accuracy depends on getting the arm length right, keeping the arm square to the sensor, and keeping bearing friction low (hence the Spiderwire "bearing").
I didn't checking it with a known weight hung on a 1" lever to confirm the scale reads true.
So there are several in accuracies, i.e. the the extension arm being exactly at 1" and  possible friction of the Spiderwire "bearing" and the brass busing, but given it's application, I ignored as these as it's small and I Can live with the errors...just use the readings as is.
Hope the above is clear.
Regards,
M
PS : I've seen one done by another patron of the old HPA, I forget his name/handle, where he employed some screws to make the extension arm adjustable for fine tuning.
Piecost
Very nice, it is very well thought out and executed.
I used a digital scale as a torque meter a few years ago, incorporatef into a winding stooge. The main advantage wad that it worked with a wide range of motor thicknesses. Whereas, I need a range of different wire torque meters for different classes of models.
The reason that I stopped using it was that the scale would time-out and switch itself off if the reading did not change for a while.
_shadow_
I've never had this scale timeout...also in the look out for similar scale to make another torque meter as now I have a mill and lathe at home.
Regards
M
OZPAF
#8
Thanks M. "Spiderwire bearing" - this has me a little puzzled.
Is the wire torque rod suspended on a tensioned Spiderwire length of line?
Is it a bushing under the brass tubes?
Happy flying.
John
Jmk89
Do you think that lining the tubes with teflon tube of suitable inner and outer diameters be a good way to create low friction bearings?
All the best
Jeremy
_shadow_
Quote from: OZPAF on Nov 16, 2026, 08:20 AMThanks M. "Spiderwire bearing" - this has me a little puzzled.
Happy flying.
John
The torque wire is connected to the rear 'bearing' with short Spiderwire.
Regards
Marcus
_shadow_
Quote from: Jmk89 on Nov 16, 2026, 08:45 AMDo you think that lining the tubes with teflon tube of suitable inner and outer diameters be a good way to create low friction bearings?
Possible, but I think the fact that the torque wire is almost not touching the front and rear brass bushing lower or no friction. But as you wind, it's bound to bump to the side of the bushings, it shouldn't affect the readings too much.
Regards
M
