  • Total Members: 376
  • Latest: Andrew
  • Total Topics: 481
  • Online today: 55
ANEC Missel Thrush
Started by billdennis747, Nov 13, 2026, 07:11 PM
billdennis747
Insights please. I'm sitting here looking at the two Missel Thrush plans on Outerzone. They each have very different approaches to the vertical taper on the rear fuselage. One is extreme, the other barely noticeable. The photos and three views hardly help. Any opinions welcome.
Bill
Squirrelnet
#1
Hi Bill
Personally I would go for the Bill Noonan one. From the book 'Bleriot in Britain' the fuselage is described as being a 'rectangular section at the cockpit area to give maximum space for the occupants and changing.. to an inverted triangular shape at the rear so that the flat upper surface supported the cantilevered tailplane'
The Noonan plan does do this though the change to the triangular section does look a bit abrupt admittedly it's hard to tell from photos as most seem to be masked by the wing . I think that, Aeromodelling God as he was, Eddie Riding took the same attitude to scale fidelity as he did with the Bristol Scout
I can scan the relevant article with 3 view if you need it
billdennis747
Thanks Chris. Yes I agree, although I waited to see what anyone else felt. That photo is the only one that really helps, with the distortion of the G indicating a more shallow taper.
No need for a scan Chris; if it materialises it will just be a vehicle to get my SAM25 in the air.
I remember Ray's big Riding model with a Mills 75 - very heavy.
OZPAF
The change in the fuselage cross section behind the cockpit looks unusual as well as severe. Surely a straight taper of the lower longerons to the stern post instead of a concave curve, would have been more likely?
Just the thoughts of a non scale modeller.
John
