  • Total Members: 376
  • Latest: Andrew
  • Total Topics: 481
  • Online today: 55
Pin clamps, self made or 3D printed
Started by TheLurker, Sep 13, 2026, 12:59 PM
TheLurker
Quote from: Piecost on Sep 12, 2026, 01:37 AM...I love the standard pins in combination with those little black, round pin clamps. A brilliant invention.
You can bodge your own pin clamps if you want. Get a thickish plastic lid, FAGE Total Yoghurt tops are ideal, and stamp out as many discs as you have pins using a hole punch. Then push the T-pins through the discs.
It's not my idea, I came across it on HPA I, but it works a treat.  The discs do work loose eventually, but it's easy enough to make new.
steve-de24
Pin clamps, I love the idea, thanks for sharing, wish I'd known of it 65 years ago! I've just tried it with the plastic lid from a 'spreadable butter' carton and it works a treat - they will be used tonight when I build a tailplane.
Steve
Piecost
Jmk89
Hi Lurk
The brand of Yoghurt is not known (or at least commonly available) in Oz and I don't recognise it from my time in the UK in the 90s.
Could you perhaps measure the thickness of the plastic?  Many thanks
All the best
Jeremy
Spiros (Spyros)
It's a Greek yogurt, very popular.......in Greece, although I think it's exported in many countries.
This kind of lid is very common. I assume you would find it in other food products as well.
Jmk89
Quote from: Spiros on Sep 14, 2026, 06:11 AMThis kind of lid is very common. I assume you would find it in other food products as well.
I'm sure it is, but I just want to get an idea of the thickness so I can focus my search at the supermarket - my local supermarket is quite used to me using a digital calliper to measure packaging  ;D
All the best
Jeremy
TheLurker
Morning,
Polypropylene, recycling code 05, and about 0.5mm thick.
Cheers,
Lurk
Jmk89
Quote from: TheLurker on Sep 14, 2026, 07:50 AMMorning,
Cheers,
Lurk
Many thanks, O Lurk
All the best
Jeremy
cvasec
I had a friend 3D print some. There is a hole but it really needed drilling out. As good as the original ones.
Ron
Piecost
Very good Ron, but they look like some kind fungle growth!
Prosper
Quote from: Piecost. . . but they look like some kind fungle growth!
Eeuuugh - never mind AI - that stuff is gonna take over the world :o
OZPAF
Jmk89
I remembered that I have already done a 3D printing exercise for pinclamps.  I have uploaded an .stl file that will print a dozen pinclamps.  Like Ron's (Cvasec), the hole sometimes needs clearing with a drill (0.7mm seems pretty good for standard T-pins.  Thicker or thinner pins need larger or smaller holes to get the right interference fit).
All the best
Jeremy
Jmk89
The upload is the the Plans Gallery in the Miscellaneous section.
All the best
Jeremy
Jmk89
A couple of photos of my 3D printed pinclamps.  The second picture shows the convenient way of storing these until needed on one pin shaft.
All the best
Jeremy
